G0 540i exhaust question. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > G30 (2017 - Current)
The next generation 5 Series, chassis code G30, arrives at dealers in February 2017. Looking like a scaled down 7 Series and riding on the CLAR platform, the new 5 Series will have a focus on lightweight and sporty performance. Engines options will come from BMW's new B family for the 530 and 540 and a turbocharged V8 for the M550i. Read more about the 2017 5 Series
Old 04-03-2020, 12:16 PM
sjb993 sjb993 is offline
Mein Auto: G30 540i XDrive MSport
Typo in the title G0 = G30. Why have BMW chosen to have a baffle in one of the tailpipes that opens at a certain RPM?
Thanks.
Old 04-03-2020, 12:25 PM
Jack_88 Jack_88 is offline
Mein Auto:
Thanks.
Noise, naturally. It keeps the car quieter when you're just cruising, opening it up when you demand more flow and expect it to be noisier anyway. It probably doesn't do a lot for noise in the cabin and probably doesn't do a lot for performance, but it should make some difference. Manufacturers like BMW are always looking for little ways to make their cars better. Just look at the windshield wipers programmed to alternate their positioning when you unlock the car, so that they don't sit in the same position all the time, reducing uneven wear.
Old 04-04-2020, 12:36 AM
OK thanks.
I was wondering whether the baffle was used as a way of regulating the exhaust system back pressure.
Old 04-04-2020, 06:33 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Thanks.
Here’s an explanation in regards to the exhaust flap (baffle?) from the TIS that goes along with what Jack_88 wrote in his reply. Click the link above the pic below:
https://www.newtis.info/tisv2/a/en/g...lap-2/Im2GgsKi
1. Electrical exhaust flap
2. 4-pin plug connection
Example: integrated exhaust flap in the rear silencers
2. 5-pin plug connection
The exhaust flap is unable to move to an intermediate setting. The exhaust flap is either fully opened or fully closed. The preferred position when detecting faults or upon failure of the actuation as well as after having stopped the engine is the closed position. In vehicles with M Sport exhaust system the exhaust flap is opened in sports mode.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 04-04-2020, 07:06 AM
Thank you for the replies.
Old 04-04-2020, 08:25 AM
Warp Ten's Avatar
Warp Ten Warp Ten is offline
Mein Auto: 2019 540xi, 2016 Z06
I don't think all the info above is correct. I have a 2019 540xi M Sport. The exhaust flap is not open in the Sport mode at start up or when idling. It may open sooner in Sport mode under heavy throttle but I can't tell. It is always closed on startup to help the catalytic converter heat up. As some folks do, I removed the connecting clip and wired it open and there was no difference in sound that I could hear at idle or on the road. Finally switched to a louder M Sport exhaust with no flap valve. --Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sport, Carbon BLack/Natural Brown, 2008 335xi, 1998 M3 Sedan,1980 530i, 1977 320i, 1976 2002 BMWCCA Member
Old 04-05-2020, 10:26 AM
jjsC6 jjsC6 is offline
Mein Auto: See Sig
Unless you have coded it, the car does not start in sport mode.
2017 BMW 540 M-Sport Carbon Black/Ivory
2016 Lexus GX 460---Wife's car
Bikes...2017 Yamaha FJR1300---2020 Kawasaki 1000SX---2012 Ducati Panigale
Previous BMW: 2012 550 M-Sport
Old 04-05-2020, 01:33 PM
Warp Ten's Avatar
I have it coded to start in Sport mode.--Bob
Old 04-05-2020, 02:10 PM
QSilver7's Avatar
I don't think all the info above is correct. I have a 2019 540xi M Sport. The exhaust flap is not open in the Sport mode at start up or when idling. ... --Bob
I clicked the link in my post above to read the functional description again...because I don't see where it says what is bolded in your quote above.
The functional description (at the link to the TIS) mentions that the flap operates by way of a PWM signal based on variables...and it listed 3:
  1. Engine speed
  2. Driving speed
  3. Load
For some reason I'm not seeing anything that says the flap opens when in sport mode, start up or when idling. It does say that if it faults...it does so in the open position. At start up and when idling...the 3 variables that would cause the DME to send a PWM signal to open the flaps is low or not existent...so the flaps should be closed to reduce noise at start up and when idling (not open). Or I'm I not reading/interpreting the TIS correctly?
(SOLD)
Old 04-06-2020, 07:19 AM
Warp Ten's Avatar
  1. Engine speed
  2. Driving speed
  3. Load
Last summer I was behind a 3 series which I could see had an exhaust flap like mine. At the stop light it was closed. Intrigued, I watched it as the car accelerated away. The flap opened under moderate acceleration. Had never actually seen that before. Got too far apart when up to speed to see if it closed again when throttle was reduced. --Bob
