Spark plug aluminum sealer tubes - Bimmerfest - BMW Forums
Old 05-04-2020, 06:19 PM
sashari sashari is offline
Mein Auto:
Hello all,
How do you push those spark plug aluminum sealer tubes all the way in. Do they have to snap in after repair works? Any specific way to push them down in without damaging them?
They came out with valve cover but have a hard time to pushing them in back all the way.
Would it be ok if they are not in all the way?
Thank you for your support!!!
Steve
Old 05-04-2020, 06:35 PM
tstiglich tstiglich is offline
Mein Auto: 2009 528i xdrive
You want them in all the way. Have you tried pushing them down with an appropriately sized deep well socket? This assumes that they have already been removed from the manifold.
Old 05-04-2020, 08:23 PM
Mein Auto:
Spark plug aluminum seal tube
Hi TSTIGLICH,
Yes, I took them out when I was replacing the valve cover gasket, some came out when I lifted the cover and the rest I removed out of the plug well separately.
Now I tried putting them back in but they are not going in all the way. they have a ridge at the bottom that locks them in when they are in appropriately like you said.
Wonder what size socket I would need. Also, the tubes that houses these sealers appear to be tapered. And if I force the socket by pushing down it may brake the outer tube that houses these sealers? Thank you very much!!!
Steve
Old 05-04-2020, 08:32 PM
If I remember correctly, I used deep well sockets to push them in. Not sure of the size, you are going to have to experiment.
Old 05-05-2020, 10:51 AM
Mein Auto:
Thank you!!!
I will give it a try.
Steve
Old 05-05-2020, 11:57 AM
zoom750 zoom750 is offline
Mein Auto:
You can try squeezing the tubes together so that it can slip past the ridges.
