Coding Panic Alarm - Bimmerfest - BMW Forums
Old 05-24-2020, 05:13 AM
RicardoBruno RicardoBruno is offline
Mein Auto: BMW E60
Coding Panic Alarm
Hello everyone, i`m looking to code my car to activate the Panic Alarm, i was able to code the Alarm Siren to US mode using NCS Expert and NCS Dummy, but i am looking for the guidance to activate the Panic Alarm and if possible activate the high beams flashing when alarm is triggered. TIA
Old 05-24-2020, 01:43 PM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
Your key fob doesn't have this?
Old 05-24-2020, 01:50 PM
Mein Auto: BMW E60
No, it's a British model needs to be coded
Old 05-24-2020, 04:19 PM
I guess it is going over my head.
If your fob doesn't have a panic button on it what good does it do coding the car?
Old 05-25-2020, 03:01 AM
Mein Auto: BMW E60
Ok, so E60 model doesn't have a panic button on the fob, the car is coded to activate the panic alarm when you press the trunk button for 2 or 3 seconds with the car locked, the trunk button only open the trunk if the car is already unlocked (mine is coded like this), If the car is locked you use the trunk button has a panic one, the reason that there is a delay of 2 or 3 seconds it's to avoid to activate the panic alarm if you touch the button by acident, what I am searching is the module name an file to code it on ncs expert
Old 05-25-2020, 05:26 AM
There are cheat sheets in the coding forum.
I have never seen nor heard of this particular one.
Old 05-25-2020, 08:20 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
The control module for the car's anti-theft alarm system is called DWA. You can click the following link to the TIS website for more info about DWA..if you scroll down near the bottom...it discusses national market differences and the PANIC ALARM.:
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
