oil change - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 05-31-2020, 02:12 PM
blink_ blink_ is offline
Car Nut
Mein Auto: 750LI & Opel Astra Turbo
oil change
I'm gonna be changing my oil soon, its a 2014 750, since it doesnt have a dipstick, how do you top it off to max?
whats this im reading about adding another litre once its full?
Thanks all
Old 06-01-2020, 10:30 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
You run the oil check level in iDrive after you've poured in the correct amount. If you are at minimum level...then add another quart/liter then run the oil check program in iDrive again. Continue until you reach MAX (or you're satisfied with the level if its above MINIMUM.
Name:	BMW CIC NBT Oil-level sensor - measurement 1.jpg
ID:	894961   Click image for larger version
Name:	BMW CIC NBT Oil-level sensor - measurement 2.jpg
ID:	894963   Click image for larger version
Name:	BMW F01 F02 F06 F12 F13 F15 Oil Capacity N63TU.jpg
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 06-01-2020, 01:05 PM
Car Nut
thanks for that, suppose its reasonably simple. I have ten litres of oil for it.
its just come up on the idrive that its on minimum, add two litres of oil. That was a surprise, I was expecting it to be only 1 litre between min and max.
Old 06-02-2020, 09:25 AM
Jerry 745Li Jerry 745Li is online now
Mein Auto: 17' 750i MSport
It is 1 quart between max and min. Because the original N63 engine has oil consumption issues BMW recommended that the dealers add and additional quart of oil to prolong the time in which owners would revisit the dealer for a top off while under warranty. They were intentionally trying to conceal the problem which lead to the class action lawsuit. Before my 2012 was totaled its was consuming a quart of oil every 600 miles. On the 2017 I picked up after 3000 miles the oil level has not changed. Now I need to see if the dealer will use the case of oil I kept in the trunk of my 2012 at my next oil change on the 2017.
Jerry
