Cigarette Lighter Always On? Possible? - Bimmerfest - BMW Forums
Old 05-24-2010, 03:03 PM
x3ronnie's Avatar
x3ronnie x3ronnie is offline
My Other Car Is A Bus
Mein Auto: 07 530Xi
I just purchased an XM SkyDock and am using the lighter socket for the first time. The socket is only powered with the engine running or the ignition in the on position. This is very inconvenient and I am wondering if there is a way to have the socket be powered under any other conditions (radio readiness switched on). The Sky Dock must be connected to the lighter socket as it provides a physical mount for the iPod Touch. I am not comfortable making electrical mods myself,but would have someone do it if it can be done.
TIA
'07 530 Xi ,Auto, Gray, Black Leather, Premium, Cold Weather, Nav,Xenons,iPod,Sirius
'04 X3 2.5i gone
'07 X3 3.0si gone
Old 05-24-2010, 04:49 PM
archie253 archie253 is offline
Mein Auto: 2009 535i MT
My local dealer claims it can't be done (reason / excuse given: the car already draws a lot of power when it's off / why would you want to add another draw?) but my level of trust in said dealer is low. It's definitely do-able if you want to physically re-wire an outlet or two, but that may be more complicated than it's worth (with the exception of the trunk cig lighter outlet, which would be a 4-5ft wiring run that will probably void all your warranties)
Would be great if there's a software switch that keeps the cig lighter relays on, but I'm guessing that the cig lighters are fed by a fuse panel master relay that shuts down a lot more than just the lighter sockets - stuff that you really don't want to keep running full-time. Would love to hear some fact-based data though!
2009 535i, 6MT, Monaco Blue, Light Poplar, Cream Dakota, Sunshades, Multi-Contour front & Fold rear seats, CA, CWP, PP, PDC, Nav, Logic7/HD/USB
ED: 3/11/09, Vienna, Austria drop: 3/25, Lv Bremerhaven: 4/14, Arr Port Hueneme: 5/8, Re-delivered to Tacoma 18 May (54 days).
Old 05-24-2010, 06:01 PM
HokieXDriver HokieXDriver is offline
Mein Auto: 2013 BMW 335i M Sport RWD
BMW is the first German car I've owned that does this. I owned VW and Audi and they both keep the lighter sockets powered at all times.
Sorry, I don't know a fix, but I would also like to know if there is one.
Old 05-24-2010, 08:55 PM
MSAMMY MSAMMY is offline
2007 550i & X3, 2002 X5
Mein Auto: BMW 550i, X5, X3
Check in the upper left corner of the passenger front footwell - there is an adapter port near the courtesy light. I don't recall if it's powered on shut-down, but it's worth a try!
2007 550i, Sport Premium, Silver Gray Metallic, Gray Dakota, Navigation, Cold Weather Package, Comfort Access, Heated Rear Seats, HD Radio, Xenon
2007 X3, 3.0si ///M Sport Premium, Monaco Blue, Gray Dakota, Navigation, Cold Weather Package, Xenon
2002 X5, 3.0i Sport Premium, Titanium Silver, Gray Dakota, Cold Weather Package, Xenon, just a winter vehicle
Old 05-24-2010, 10:43 PM
GoRavens's Avatar
GoRavens GoRavens is offline
Mein Auto: 2007 550i
TIA
Why do you want to run/charge it when the car is off?
2007 550i Black Sapphire on Black (Sport, Prem., Nav., Cold Pkg., Logic7, Comf. Seats & Access)
-Hard-Wired Escort 9500ix, Black Carbon Fiber Roundels (body & wheels), Black Kidneys, 35% Tint (sides & rear), Cont. Extreme Contact DWS, R1 Prem. Rotors w/ Hawk HPS pads from ACUTE, OEM MTech Front/Rear/Sides
Old 05-25-2010, 02:47 AM
x3ronnie's Avatar
Mein Auto: 07 530Xi
I don't want it to be ALWAYS on,but having it on in the accessory position would be nice. I can listen to the radio this way,but not to my XM or iPod when connected through the skydock/lighter socket.
Unfortunately my 5 does not have the passenger footwell lighter socket. This would not be helpful anyway,as the unit has to be physically connected to the socket and close to the driver as well.
'04 X3 2.5i gone
'07 X3 3.0si gone
Old 05-25-2010, 05:25 AM
Nope, same thing.
The manual says all power outlets in the car behave the same as the front cigarette lighter.
Old 05-25-2010, 05:30 AM
In my case, I have a small tire pump that I use to set tire pressures correctly when the tires are cold, in my garage.
I don't want to run the engine while doing this because it would waste fuel. So ironically I turn on the ignition and set my tire pressures - I say ironically because I'm using up the battery faster that way than if BMW let me run the pump without turning on the ignition.
I usually hook up my battery tender overnight after setting pressures.
Old 05-25-2010, 10:11 AM
x3ronnie's Avatar
Mein Auto: 07 530Xi
This is just another one of those "things" that I dislike about my BMW. Add it to the list. Sat Rad is prohibitively expensive and proprietary as is iPod interface. Most vehicles would allow the lighter socket to work with the ignition in the accessory position. Certainly the radio would work in the acc pos.With my X3 I loved being able to turn on the radio without even doing anything with the key/ignition. Now I can't even do anything until the iDrive screen boots up. Waiting to turn on the radio,or select something on my iPod is not my idea of a premium vehicle. I will get used to it,but thought the 530xi would be similar to the X3 I had grown accustomed to. Guess I should've done more research. If anyone has any idea about how to get the lighter powered without having the ignition on,please chime in.
'04 X3 2.5i gone
'07 X3 3.0si gone
Old 05-25-2010, 11:50 AM
Spyder's Avatar
Spyder Spyder is offline
Mein Auto: 650i Coupe (soon)
Rewiring the cig lighter to an unswitched 12v line would not be difficult, but this solution is trivial...
http://www.amazon.com/BMW-Genuine-Au.../dp/B000NCNB92
The device simply plugs into the flashlight socket in your glove box. That receptacle is always hot to keep the flashlight battery charged.
Spyder
Old 05-25-2010, 11:59 AM
x3ronnie's Avatar
Mein Auto: 07 530Xi
Spyder
Thank you for the adaptor solution. Again, the unit that I am plugging in acts as an iPod dock and needs to be connected to a fixed location. I need to have the lighter socket powered. What about the rewiring?Details?
'04 X3 2.5i gone
'07 X3 3.0si gone
Old 05-25-2010, 12:15 PM
Spyder's Avatar
It's never difficult to find an unswitched power source, eg see the current V1 thread. The dome light assembly has both switched (suitable for the V1) and unswitched wires that can be tapped. Also, the hot wire to the flashlight adaptor could be tapped for an unswitched source.
As for iPod/iPhone mounting, powering, and connecting to the OEM sound system, this solution is the best I've come across...
http://www.2point5.com/
I purchased their unit for the 650 but have yet to install it. In my case, and older gen iPod lives in the glove box, and is connected to the OEM sound system via the BMW CD emulator. Hence, I use iDrive to play iPod music, but I still needed to connect the iPhone to the aux input to play Podcasts and Pandora. That's where the spec dock fits in. I really like that I can just pull the iPhone out of the dock, close the ashtray cover, and have the car appear entirely stock.
Spyder
Old 10-29-2015, 07:08 AM
Katiemac1956 Katiemac1956 is offline
Mein Auto: 2011 3.5I X5
I had a 2004 X5 that had the feature that the cigarette lighters were powered when the key was out. I loved it. The power goes out a lot where I live and it was handy to charge my electronics when power outages occurred. I recently purchased a 2011 X5, thinking powered cigarette lighters were the norm in BMW's only to find out I was wrong. I miss that feature and would love to have it back.
Old 10-30-2015, 12:07 PM
H F H F is offline
Mein Auto: 2005 545i
If wired correctly , you can run fused power inside the car . Either an independent source for a phone ,, or directly go any lighter socket . I've had a independent ,designated double fused power source for my iphone . Charges whether the car is off or on . Think it's been more than six years now ,, and haven't had a single problem .
Old 10-30-2015, 05:33 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
Yep. Easy to do. Probably an hour to wire a live lead to the front console lighter. You can use a lower capacity lead if you don't use the actual lighter element any more, just the phone plugin.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
Old 07-21-2017, 04:26 AM
jimmy_rock jimmy_rock is offline
Mein Auto: BMW X3
Hi, Im looking for a solution to the same problem, is there a way to get this working please?
Old 07-21-2017, 05:41 AM
twh twh is offline
Mein Auto: '06 530xi 6sp
Not sure about your car, but my 2006 has a BMW flashlight that lives inside the glovebox area. Open the glovebox and it's to the left. The flashlight plugs into a special socket. I have an adapter for that socket and I'm pretty sure that is powered all the time.
Old 07-26-2017, 08:20 PM
Mein Auto: BMW X3
Unfortunately my car doesn't have that
Old 10-28-2018, 11:46 PM
VADMBB VADMBB is offline
Mein Auto: 2009 X6 3.5
Cigarette Charging work-around
Recently bought 2009 X6 in immaculate condition. Imagine my chagrin the day my phone died, and I realized I could not charge it w/o running the engine?
My work-around was plugging a USB battery bank into a hi-wattage plug-in charger. Plug your devices into the battery bank, they charge while engine off. God knows there are already to many parasitic drains, anyway. I'm a huge Anker fan, have not had any problems w/ the wide range of products I've bought. . .
https://www.amazon.com/Anker-Charge-...web_2528932011
https://www.amazon.com/Anker-PowerCo...20-834474eb-45
Old 10-29-2018, 01:02 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e60, f25
why would you even consider useing a cigarette lighter plug to power anything
thats tacky
fuse block tap, find your fuse that is live all the time, (after the 15 sleep mode)
and then come back when you have a dead battery cause thats whats gonna happen
Specializing In Breaking Things Professionally
15486372<-----
Old 10-29-2018, 12:03 PM
zoom750 zoom750 is offline
Mein Auto:
In my 2010 e60, the usb port in the center console (next to the aux connector) has constant power.
