Center Console G12 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - G11 / G12 (2016 - current)
The next generation G11/G12 BMW 7 Series flagship forum. Unveiled June 10th, with production starting in August the 6th generation 7 Series comes in a light weight package with extensive use of BMW i carbon fiber technology. The interior quality raises the bar with a touch screen and gesture controlled infotainment system. Exterior styling has been a sticking point with mixed reviews so far.
Old 08-29-2017, 10:56 AM
Jflint47 Jflint47 is offline
Mein Auto: 2016 740i
Center Console G12
The sliding door for the drink holder stick in the open position when opened all the way. Has anyone else had this problem?
Old 08-29-2017, 11:24 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
I moved your question to the G12 forum where you should get some model-specific help. You had it in the new member intro forum .
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 09-03-2017, 04:26 AM
doabbado doabbado is offline
Mein Auto: 2018 750; 2016 g550
are you sure it is stuck? the sliding door has a two-stage opening (one for the drink holders bit and one for the lighter/storage bit located just in front of the drink holders) that allows you to open just the part you want. and to close both sections, you push the door forward slightly and it will then unhook itself from the built-in door stop hold and close on its own. works this way for both stages of covering. give it a shot.
Old 09-03-2017, 09:14 AM
Thank you for your reply to my problem. I apparently miss spoke about the problem. I've owned the car for two years and this problem just came up. The door works fine when opened to the drink holders, but jams or hangs when pushed to the full open storage position. It will not release from the locked position unless you pull forward on the door and then push on the door to release it. I've spoken with the dealer and they tell me that they are aware of the problem. I'll advise what they do when they make the repair.
Old 08-20-2019, 04:33 PM
This is August 2019. I had this problem as well Hopefully you have had it replaced under warranty by now
