Night Vision Camera (NiVi) repair - Bimmerfest - BMW Forums
Old 11-28-2017, 02:14 PM
cigas4 cigas4 is offline
Mein Auto: BMW E65 745D
Worked for me. See video bellow:
Old 12-11-2017, 12:32 AM
vibbelito's Avatar
vibbelito vibbelito is offline
Mein Auto: 2007 730i E65
Thank you, I have actually been looking for this for some weeks. Or a possible way to change the lens altogether without any luck.
What did you use to polish the lens after all the sanding?
Old 10-29-2019, 05:23 AM
cimdahers cimdahers is offline
Mein Auto: BMW e65 730d
I think this is short term solution, since.the lens has coatong on it to protect it. Read it also somewhere in a Russian portal
Have tried also sanding, but i was not able.to polish the lens to mirror shine then, and switched to research how ro get a new lens instead...
Sent from my LYA-L29 using Tapatalk
Old 10-29-2019, 05:31 AM
It is possible, that it is short term solution, but this short term is enough to realize that this night vision feature is useless While driving on the road you are not able to watch at the monitor and at road at the same time, it is not safe. This old version of night vision system does not have any object recognition or notification possibility, so basically it is only a nice toy to play few times. It makes no sense to pay lot of money for new lens, because I am sure you will not use this night vision option
Old 10-29-2019, 05:43 AM
Hi, yes.
You are right that this version comparing to the newest is a bit uncomfortable. Especially I like the new version with the beams which are aiming directly on the identified object.
However, I've got used to this first generation cameras. This is confusing that you switch off your sight from the windscreen to the control display, however, you are still looking at the same driving path. I got used to that, but if not then yoi ate disoriented and it dangerous indeed.
If could I would retrofit the new night vision version. Anyway, now I use this version, and think that it is better than nothing. These dark times I see such objects.there which normally cannot be.seen by your own eyes. Our pedestrians are still very dark while not using luminescent materials and brighter dress. Sone of thembare even walking on the road, unfortunatelly I have seen such tragic o***269;urences where pedesreians were hit byvtheir own fault, but the driver is in his worst nightmare...
I choose to prevent that.
