Track day tyres - Page 2 - Bimmerfest - BMW Forums
Old 04-22-2019, 10:13 PM
Rotorblade Rotorblade is offline
Mein Auto: Bmw x1
I suppose ps4s is the plural for ps4. They seem to provide good grip and I've also noticed they do very well on wet roads. The road noise is also low. Anyway I haven't use any other tires on this car so I can't make a comparison.
Old 05-08-2019, 01:47 PM
Mein Auto: Bmw x1
I went today on a small track with the 225F 255R PS4, temperature 12C, pressure 2.1 Bar Fr, 2.6 bar Re and they didn't feel as grippy as the 255F 265R ones, possibly because of the track temperature or the tire pressure!?
I also have a system, not sure exactly how it is used, but when a certain lateral acceleration is achieved there is a weight that slides on a bar and you can hear it rattle. This time it would do anything... it could be stuck also
Old 05-10-2019, 06:23 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Everything else being equal, the narrower tires will have less grip as their contact patch is smaller. No surprise they felt like less grip.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 05-12-2019, 07:51 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Actually the size of the contact patch remains the same with wider tires, it just shifts it laterally.
[SIGPIC]
Old 05-13-2019, 01:09 PM
Mein Auto: Bmw x1
I've watched a test on different tire sizes on a 3series and it showed that for a wider size tire the pattern becomes wider but narrower (because the tire doesn't deform under the weight of the car that much I suppose) so the area doesn't increase that much. Anyway the wider tires had slightly more grip and with wider front tires there was less understeering.
Old 05-13-2019, 07:34 PM
dc_wright's Avatar
The static contact patch doesn't change much with wider tires, but the dynamic contact patch changes dramatically. As you laterally load the tire and the tread starts to roll under the load the wider tire has more tread to roll through before grip drops off.
Old 05-13-2019, 08:52 PM
Yes wider tires will increase the lateral patch/lateral grip but at the expense of the longtitudinal (fore/aft) patch used for acceleration and braking. No free lunch here.
[SIGPIC]
Old 06-05-2019, 04:09 AM
Mein Auto: Bmw x1
On the front the 225 ones heat up quickly on the track, the 255's were very good. The problem is I have put the 255's on some JR11 rims which have a ET that sets them further away from the hub than the OEM ones, that's why they touched the wheel liner. Even with the 225's the clearance is not perfect. I have a set of old OEM M\\\ rims, I could try with the 255's.
Old 06-19-2019, 08:49 AM
Mein Auto: Bmw x1
I did another change, this time I fitted the car with a set of OEM M rims. Because of the proper offset these allowed me to install a pair of 245/55 R18 tires. The 8" width looks good and is within specs. On the rear I have the 255s. Now the car feels pretty neutral through the corners. If I take a corner too fast, often both the front and rear start to slide. They heat up quite quickly but anyway the engine is not prepared for sustained effort like on an M car. The oil is too thin and the engine cooling I suppose is not that effective so I think the best is to do 1 timed lap an one cool down lap. The brakes are good enough, I have upgraded them with cooling ducts.
Old 06-19-2019, 07:33 PM
dc_wright's Avatar
So long as the cooling system is in good condition it will be fine for sustained lapping. I have stock system and it's been fine running full 25 minute sessions in 98 degree heat.
I run either BMW 5W30 or Pennzoil Platinum Euro 10W40.
Old 06-19-2019, 07:51 PM
Originally Posted by dc_wright View Post
So long as the cooling system is in good condition it will be fine for sustained lapping. I have stock system and it's been fine running full 25 minute sessions in 98 degree .
2x, stock cooling system is up to job. Stock brake pads? Not so much..
Old 06-19-2019, 09:48 PM
Mein Auto: Bmw x1
Thanks.
I have Ebc yellow stuff pads, ebc discs SS brake likes, RBF660 fluid, and cooling ducts down to the hub, but I didn't do more than 7minutes before a cool down lap.
Old 06-21-2019, 07:34 PM
dc_wright's Avatar
Thanks.
The EBC Yellows will do OK for the tire setup you're currently using. If you get a tire/wheel set with more grip, you'll be carrying more speed and you'll need higher temp brake pads. Check them after every session as the EBC pads will start to disintegrate if they're overheated. If you see small chunks missing on the trailing edge of the pads, particularly the fronts, that's a sign they're about to come apart.
Old 06-22-2019, 12:29 AM
Mein Auto: Bmw x1
Yes with slick tires you come out of the corner later, brake later and harder so much more energy to dissipate. The first day I used them, I didn't have the cooling vents and drove several laps until the liquid rbf660 boiled, and the pads lost little bits from the edge as you said. After that I didn't use the full force anymore but something like 80%. Now they have like 5mm width of material left. I suppose they need to be replaced as soon as possible
Here is a video with my car
Old 06-22-2019, 10:41 PM
Good stuff. The telemetry is cool also, nice to see a sustained 1+ G in the corners.
[SIGPIC]
Old 06-23-2019, 02:29 PM
Mein Auto: Bmw x1
Thanks, there're probably some improvements needed with weight transfer, and found some deviations from the optimal racing line.
For the telemetry I use the vbox gps which gives much more details than the phone gps. It also helps when analyzing the data with circuit_tools. But sometimes it doesn't receive good signal or the signal doesn't get validated.
