DAS VADER: E39 Touring Build Log - Bimmerfest - BMW Forums
Old 02-17-2018, 07:00 AM
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Mein Auto: E61
Most of you probably know me on here for my Twin Turbo E61: https://www.bimmerfest.com/forums/sho...702&highlight=
I picked up an E39 touring to use as a temporary "beater" while the e61 undergoes some repairs. At the time of this initial post I have had the E39 for 5 months and it has received a tone of obligatory maintenance and a few choice modifications to reflect my automotive style.
The plan is to keep this thing reliable and and the driving dynamics solid, buuuuuuuut when the auto trans bites the dust it will probably receive a manual trans. I mean; a manual V8 E39 wagon? It's the obvious choice and considering BMW never imported and manual V8 wagons there is a strong case to make in terms of "value" that the swp will add to the wagon.
I will stop the predictions there because my old E39 M5 and E61 were both picked up to be relative "beaters" or remain mostly stock and we know how that turned out so who knows what is in store for this E39 but I can guarantee it will be clean and functional.
Evan
Here it is the day I picked it up: 2001 540iT 127,000 miles. Black on Beige, Auto Trans, Non-sport, Cold Weather Package, No Nav, Optional 3.15 differential
N54 Powered M5 Wagon:
- M5 Driveshaft, M5 LSD, M5 Axles, M5 Brakes
- M5 Front End, M5 skirts, M5 Mirrors, M-Tech Rep Rear
- KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC
- Manual Swap, MFactory SMFW, Spec Stg 3+ Clutch, Shiftteck SSK
- EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Ethanol Sensor
- N54B30, JB4, Hexon RR550s, Custom Y-Pipe Inlet, AR DPs, 3" Exhaust, VRSF 7" IC, ER CP, Tial BOV, RB PCV, BMS OCC
E39 540iT:
- OEM Style 167, KW V1
- E38 Contour Seats
Old 02-17-2018, 07:20 AM
ucsbwsr's Avatar
Mein Auto: E61
Here we go....
Rear wiper delete
Lucked out and found a E39 Touring at the local salvage yard, pulled the Black OEM window trim
It needed some refurbishing
BEFORE
AFTER
Dead pedal was broken, beige swapped to black
Rear bumper was out of alignment
BEFORE/AFTER
Removed all impact trim and Dipped the chrome black
Smoked side indicators
Engine Bay
[IMG]https://lh3.googleusercontent.com/Gej7BORd9Xi2kl1ftCnr_Q9hy5aBl7VZe5PZMzQYnQxeAxC5cJ ScmFOEjlv33tM9VVzoERZucqTBlPud40ZbekEI9FdG4EDSKb5a D9cmf61_ZjwTUClunKYZ09rXhgGCYnIlr3TQoGi_sGt1bNFRUD Atwe1iQGs48ChvY94PuJ9Am6OyeX8iINmMLMn2e1Vp4b7zALg2 CenHRMHu0nKPdbcyij8zfQN1d2aK33WFL31r9blYsYDUK6svhF km4Q1euNd3zRyenocgoHjmHzp-QQnVMDs9qhmnLuKKnRB***uJix9byD3UibdUQ8zo8FHtQOngII S-viivXC8JSiRF4vI4TDyLs1sQm4HVpalM6a3CaMzXYd4InUvTt5 ovuz_jyx5f5KA90Ao0oPx_Tl3jlIONdBzrq1UHu_aqnYBwqjp0 aZXOaavA-9b9q6BV3MQ5HoBwJHU3w6Mk3rltJuTYFyaUOu7P3MJAnEJyUNU CYnlAWT6As7uVPuwGouJX4rOeJu0PCn7MNGBSWZces04I64Qv4 PyTUUklWiuwmGdO4HfLQtRK7gQgnoxYx3uJErR_8l1KooyhIgU g1PmnvLtnS47IUkV_Q8ZBUKYuGJSy=w1316-h987-no[/IMG]
Intensive reservoir was a mess
Deleted the system and removed the mess
Replaced and rerouted some vac lines to clean up the aesthetics.
Junkyard score
Replaced damaged arm rest
Gutted
Mostly converted
Muffler delete
Valve covers were in rough shape
Decided to replace gaskets for the front upper timing chain covers
Back together
[IMG]https://lh3.googleusercontent.com/kNok49Yqv1IwVBmINx_kFnDnn516vQOtwLxZU3JVkFaQki2Pd8 WTzhbfuQYCJTMCyjmlwyaktJ9EnuXt934Cma2K78-vp8na4KAH1O5xfPHox06onJlJGOiy9arvS6ASzJfCSw9zbQQwR x2L_0Zh_7pCbPB1JTuZ0U89DWmnkohskkHwR1uelyjuScTqDCb O8gcZ7h9JEGsrb0uJe8HhZYEOrQ7AmPZqamlx3xsMwt9VVErk6 Ar3u1vETnIoCwpQfPVn***fJx5i3nGB8juUB2SOy2hrR1YMCQJ a96FlAEs2W1Xgblwv2eyrNz73E7Q3sxhuy2FfdXT5zNgohu0_o IHXmiD_CbnHRu2Hg0_qhdRWIV70b6DJ2jZDuwgFvVOI8Sdeagy jDr3a9yctVVFQMRZyp8jVRVzei705DZnuu_0xEcBjNYP0y4UJY zMs3W49CC6uQziWP4VvHPK5zZzkOXNZSpWpiWnxpy-xdDnM3ErQeFuh3BfrGqlvrobIjK6y6B1okhYR4V0_pKde0u4Qs 9sV8asNPSMevIat1Ah1pYbnpqzyvBKOkwao8kcJBP4ibRBeLqp tQ2JwCDPDDmS4AYZf_zzgJ5wk1Mc-sw_s=w1316-h987-no[/IMG]
New oil filter mounts and steering fluid reservoir gasket
[IMG]https://lh3.googleusercontent.com/3i6ahDeA-RAMPlxemGN5lazp8nl5fEbBW-foqNZr7AfR1iKV98Qaym4io0DOKRRZG5CYEaTIw6epjCCWx0IP xbBRdRhP6CkUB0FGxWWu8MuCCeycm3p8eBQcwZ95NWtEVUffY6 Q3jyw_NJWqgBCPBkKp2lhXI7nWfiq-fItuv5tuqaFq27A2YQwAzPF784B3dFAKSaz7KYiOXvj3a6uKfe kli2IMpkkdeFzGsjYURhdj28ns18TouuoQ99RBKxJW954LnxGS 5Ja79XKF3JrnO6kIY3Elf7S0qkG9R9JsUwvyCSZzU7EiodDNBu zTT5Rhiq3k4q2Pj8hZoqady_PvwF7I56uUJ83iRvuXby11UxHM ZNswmj5enf-5azLNp-EnqtyFp3OISJleZDP1iHgnYUBfgUxczzilhfScawx-EYp5iGpDBk9bvBjhypimcTSinX5caB1nCZdnAQ0Hwa1o7Dqo6Z _k1MoarIvX1_m-S1WdcHS7NTNewYwnp0RWWM9o-RhvM6SVGvJqYyh7cCj5P5e8zV-xVfTAnyrGsf9OlDZD1IFijGShNqXUgYW9YnAsk4fuFaNerFLTP kND4hYpLb9ZykU***9D-0ZbZxFt=w1316-h987-no[/IMG]
Windshield surround was disintegrated
Removed
Replaced
Cowl was replaced too
Installed an EZ-LIP
Shifter and console trim was damaged
KW V1, 72.56 hub conversion, new top mounts, and wheel studs
E39 540iT:
- E38 Contour Seats
Old 02-17-2018, 07:47 AM
ucsbwsr's Avatar
Mein Auto: E61
OEM Style 167
Black kidney grills
Front plate mount delete
Black oem all weather mats
Coilovers going in
74.1mm to 72.56mm
Time for the rears
Coding the ride height via INPA
Need new tires to get the ride height dialed
Oil Change
monochromatic roundels
Gauge cluster rings
Wheel swap just for fun
I guess you can say the transmission mounts were "worn"
As were the engine mounts, lol
New roundel for the front
Monochromatic of course
Suspension rebuild
OLD/NEW
Fenders rolled
Headlights
Lexus RX AFS projectors (custom curved shields and E30 clear lenses) were retrofitted, Osram CBI bulbs, OEM Hella ballasts were "boosted' from 35w to 43w.
Angel eyes disconnected and rings frosted, high beam bezel blacked out. New lenses
Output
[IMG]https://lh3.googleusercontent.com/KBa7yaJCLE_f-kvNzbjhqApVdouQvuYgp3Cf-Eo44kSrLVgx50__8nPTzrhFYYAL_Q12bteBWJh6Vltk2UI4Jzd YvNwwfGJOZUF-Kt-ro0vO6ow2d_0aIyZD_zH9zqQPXus4Ez6yK2scvriPKn9cM-AEwR2FOQAkotQdgpM4ZvqFK9xWJK-se8xfRhQzTQ2QyvoQhWyg2p5s9z0rQeBwlfjMftUZ7gfjuiX4B _82B--Ebsk6Vj1SXExL7T4_M2nMVr8qLpuZO92-c1szsGsuDqPc0uOL5LUIUwM4sBJIjA3w0NLxl6Ggy7yeCx7x01 Z6WnnTmKMZ4TmSZUW9FepbjuxWuSEh9YMUQ84rFL8IDN_8_eHD ***2qTkuZ-oEGR50d2j8ZQ519OCoo-gkcdD-XfJq3T1bIyVRBn8wz-MlcaxG7jBf8XEHLZP9F1PV72dRKZKAGJQjzLsNw9Sxw37BhZQ6 j9H3j733q5PhLzOeKDQdvGk1TMHfaGVW2wGzt00xdCgA4J0u7B tlQp-rsaJmPCit6_BXUAGyQHO2APfAyRlgsd7faCvQx5hBiT0yZIR6E MURGJkmNqrWPXvjbzobppWrolnSQdaJdD46kHwr=w1316-h987-no[/IMG]
[IMG]https://lh3.googleusercontent.com/H68fQXGBmA9p6xXRaxj_Y0xZuksh8VndcQQJCLkyS9o1sdE2k6 0DAEayDoQqZdBmrbUUFaaY8TuJA8f7T3Bo25Y5i8t8eUACHBlQ 1aVSL4i0VhREwkD00A7mRgOo6n5LhTXf6SJTjLVGmPBzn8K2xH nkC3i-LWO87a-uII7Tsfdc_Umxo0tS***zw97sf7feD0FN0CmwfFr-NrjJQXHvcu-JXwOyMflDCvyRnia--NEPpt0OVrjEu-PoispWK84oFSul8yWGiOAE6ut_TjINlUQOtVm30ugzUqqFuvt-yYAu0G0IiWXi05GPpIGI-qvhgMled-crCwZSPnXf-xWKnXK1CbJKEAVHVeWSHRT0CLJZsMJZG5LWPyb0AHody8QGHbY JgBsoUOPyxT9Nt2N20izDb7HmCi50rPsKEyjbVhZ2xKZNOL4xb v6k7uUgHJXtBP_wgrJ1fZ0vp-iqKYCbjk_3rnnWxILm-UcGBF3COt-YoTVhFUmbTc6oe-ZPATAdW3wS47zjn0m_lPJvoVWX4vp-9gOVBZQypG5ntz7yiSIXV0mqE92pP7HUUxavENFwkqajiwWiYl lfGR_hcADNnIonq_yk-X5Ykwrb6YeH=w1316-h987-no[/IMG]
Hmmmmm
[IMG]https://lh3.googleusercontent.com/K-XV__b44a-SypHqrQXVWpEEAZryYW3UKZL7Of4aQZPJdJyi-Ggsg7CPm2SWgmDzq0p-PNgLLX5xIYw6wC7TFn91o6OEu_r4UhNfsVPq-XGGmTruEN5lGoQqmwdi7dtbKdZwIrN0i4v3FA6vpV3IKLcpI0q uMqCuKdc33CKMyn0_2of3n70hYNoDQeNmGJVqAdiQeiWb6A-wOM__tF_0ImNXVCJswhEY46HkwrPKubb7W***qwqvIu_Bfa8GS yuxv3e9oqC3NoN2gWpZVOszTmsszWlZqr2BSFVc6rC3hL42_rt CTeOi-lokU7MEoAE7qR8Om2EtDW5e8xgVmwWCk_owDJ2ofctd6hW0sVs faBwE01NBlV66t4yqo-Ha-CD1zskHB6Xy7JJcAAc4srYpl-sn3TncRiQue50eKlWCJ7LoRuRhcUzoA8unnv0XlN_aO5kbGGfg OkEyyExvA44gvrzL1DOJqtbLFN04IwIjpMBoMOs1MnKFgcScj4 AtbrXa1KzlKrqKUi76FtLNRb_nhsl-1zOwMNC6IaJu2symiBzUPE6jAfzSDQ1Gj69fPrxXDxBIxZeAf5 EF0VWCetgJGIjCLln0ahdkEscocKBI=w1316-h987-no[/IMG]
Current look
[IMG]https://lh3.googleusercontent.com/trdd_tHYxljxZ0Iu5sVPrK3VK2JWtAjwUkWmmDi2GiAD2QDzjp ZZaOduwF_E0hS9QRkM-HFLq5BPFOOhR***cgYkLBzK4nF0Ye8UzE0BqUOwc4A0RwPBv67 1N2pzyNrkbAYulypLnKbPhTPai4UzmR7vPdl3JtCjMyPYu4MgZ pG1Vdr9NAFiYRhHjKWAVBQcGMnFVRXcvJIFSf_FyMULTRqsihH K2avQBhMloy_9AL84CsumomvWu7j0oqTqRjCphuX-EdJHTX-gIJqMUH5KgDRsz2oW1LWRSd-m9ODp1Kwl5zFWZdcSLVtRsf2OWnCECTHNxCxXmmrI68f9ZYs0n dxn2Hm6dOoPr8ebPpILq_DUOPQDZc0veoE9bmmRyD6AoLyDHvJ y9bYkIJ52lDrK4YLtW3X8Yufk420xnwZduNm6rXo2LrDHuM_34 l5QCNgso1-g37LjCC-Swa3udecwhnolIFmM7tl0i9zr5gZpJszAa7RaExqU4o0LrB-WW8LX8yLl4OxbhAWxNA8irF3YkH9GgeRhHCjPAi9FfB4k2We1j TKLgF4VUe85e0XmwXbKUVPsBH9BqhRUz_x3PVGKVvPoZo2BWDJ mINNjTfb7=w1440-h987-no[/IMG]
Another salvage yard score
E39 540iT:
- E38 Contour Seats
Old 02-17-2018, 07:48 AM
ucsbwsr's Avatar
Mein Auto: E61
Remaining cargo area trim, dash trim, and some other goodies
Trim swap
[IMG]
https://lh3.googleusercontent.com/CbZirMpOCjRCzYFpDDiDbUt0hfuyBDRRRU5UIuZNMhC_U2Vv4U yUT98NJC06SXE2N4LnhMUfxW9WCovtgQ5NvLJewNocDP3Poh2Y aewt22IgL2kY_qPnceCzkCjVRBnuyLFjek7BMmQ81Aiwb06Mzt CAfX85q7KHWcTIjLY6XT-RKowgNqL3k30eUfczFqo3C-2m8ZAEGd0PuBSWgzGgn_M7rfyZOO0pNb8Pz07aHqr2qrNjr7ks am6bIFPM5lc_qRq65i1Bntadilv3nxzxj2dFPiWuKQZpInv3BN uNDiI2IzKu1BEB8X17eht-xf0NeaCzNp8myvsnHLNY4V25WpyULvGQYE0ABCjAGJujKo_t33 YibJAWVSa0MrvtUPOTJBPwR8q9OwTPAhbB8gUHA4MXzxa_e-cxLdgk7UCTVbahWShWA7-WxYhExn9Eu50hEkaNvBPIxqhuSGGKKMraEc82kYhEeHTnqcaAy MSy860HWpk04_dDCHROGxJa9e9gJGm6HgAqtN9R0SIrjRoTPYM uZ-E-K9_ADH8JbPvxWFfnKvq5vvrx3Lni8CjhEtPw-FpWWCcSqDGQ9biEhlqid5brU2vquhMXI2yphMFN=s987-no[/IMG]
Repaired hood release
Another salvage yard run, more black interior trim, M sport steering wheel, weather stripping
Vanity plate arrived
LED reverse lights
Executing LED projector fog light retroofit
Top: OEM halogen
BOTTOM: LED Projector
L: LED
R: OEM
Tires went from the original (came on the M6 wheels) 255/35F 285/35R to 245/40F and 265/35R MUCH better for ride and fitment
Bright lights, no glare
[IMG]https://lh3.googleusercontent.com/TrvpiJ73yLlYo_6vgCzcR351uGFPKR8jDouwZiIzKFSDRXH3K7 mXf6lTg72lQjuIePPUHHaUm3Q5NKEhIxQ2qECTj8LroCdcN5y2 bKoFpe4Zg7TAISsB6Ch9UPJy0HQsmUvCahC1dyaJ***nNGDPeG 4_85fMrtsk-Y0ZO1e8D4rP1XZAgEh4AmQfC9VcywIuyQR2t9KJSdY8a8xnxaN t4EuuXUjEpBeEpdHi0Lwg6QMGmYJH68qILvNVbCV8kG17qebZM SC4OV-xLXFKXU_3UPEBnEkbvMdqmwfe0E9pKbeKFTWgi3tpiI-18ON5OTR4tjHz8cn8J9WimMucknNJWvjknzNIq07riARUfvelX P21m9YoOLbe5XB_nOLGQmaEITX3975FQQRIw_teSkKiycsTz9Z Orv14Bcyt62-0kVWrao5C53LrQKiYPr1_RzDfDCpya2ZA9wXCt8KDJzyIHolN_ NWPjHGnnZ3EtIVK_Q7Tc8ZU6ltDHV7Wz2sDLzDynVKPq0CnhGK XrmuyQEwbsqlGkiKmZDupjQ4FOdznfT-F_9pt4VCMO21vcrxl8H6tIMlMlUOJKBCgag3UTr8_dUHSq6FH2 sa5IKPm346G=w1316-h987-no[/IMG]
New rear hatch and glass struts
Toying with the idea of mounting some of these Viper ACR diffuser fins
E39 540iT:
- E38 Contour Seats
Old 02-17-2018, 07:55 AM
ucsbwsr's Avatar
Mein Auto: E61
M5 style mirrors
LED license plate and puddle lights
A better look at the cargo area conversion
I deleted the front wipers so I applied some ceramic coating to keep it slick
With her washed up I took some pics, much better with the M5 mirrors and some proper fitment
...on to the next...
new subframe bushings, can you tell which one is new?
New differential bushings, Meyle HD for the rears and billet for the front
Took the opportunity to black out the muffler delete
E39 540iT:
- E38 Contour Seats
Old 02-17-2018, 07:57 AM
yuhan67 yuhan67 is offline
Mein Auto: 520i E39 1997
Man, brilliant!
Sent from my SM-T805 using Bimmerfest mobile app
Old 02-17-2018, 08:53 AM
MotorMark MotorMark is offline
Mein Auto: '15 X3 35i
DAMN good work!
[SIGPIC][SIGPIC]
Old 02-17-2018, 09:08 AM
matt540's Avatar
matt540 matt540 is offline
Mein Auto: 2000 DINAN 540, 1983 745
Why would you delete the rear wiper? It comes in handy because the rear glass gets dirty very quick.
Sent from the moon
2000 Dinan 540 Dinan F&R strut tower brace, M5 F&R sway bars, Koni Sports, Eibach springs, Powerflex polyurethane bushings, Dinan stage 2 engine software, Stage 1 trans software, Zionsville cooling kit, resonator delete, Dinan exhaust, Dinan TB, AFE cai, 18" style 5's, 235/40/18 275/35/18, Ultimate cup holders, rear cup holder delete/coin holder, Hella taillights, clear sides, Depo AE, M5 spoiler
1983 745 turbo, style 138 wheels
Old 02-17-2018, 09:10 AM
matt540's Avatar
I like what you are doing with it keep up the good work!
Sent from the moon
Old 02-17-2018, 09:56 AM
ucsbwsr's Avatar
Mein Auto: E61
Originally Posted by MotorMark View Post
DAMN good work!
No plans on stopping
Regarding the rear wiper.
A) I live in San Diego
B) I never use it
C) I keep my **** clean
E39 540iT:
- E38 Contour Seats
Old 02-18-2018, 01:49 PM
ucsbwsr's Avatar
Mein Auto: E61
With the subframe bushings and other "guiding" suspension components replaced and the suspension finally locked in place I got another 4 wheel alignment done.
Here is a better pic of the blacked out exhaust installed.
Thought about it, the Rigid Duallys would fit with some work and look pretty slick but I am not sure it is worth the effort stuffing them into the small tail lights and then running a relay harness through the tailgate and into the rear cargo area. I will probably end up mounting a small LED light bar by the differential like I did on my E61, better output and much easier to do.
My bumper impact strips were originally gloss black with small chrome strips and after taking possession of the wagon I Plasti Dipped the chrome but left the rest as-is. I then received an OEM front middle impact strip (license plate delete) which was primed and unpainted, to help blend it in it was also Plasti Dipped. To bring some consistency to the trim the remaining gloss black was plasti-dipped so now all the bumper impact strips are identical and resemble the matte finish of the factory M-sport trim. As a bonus the Dip is hiding some blemishes on the original trim and helps hide the PDC sensors.
Here you can see on the bottom the front middle impact strip which was already plasti dipped just next to 2 other strips prior to dipping.
AFTER
I decided to follow through with the small diffuser project I was thinking about. At first I was hesitant because I wasn't going to be able to build it in an ideal manner, with the exhaust on once side the spare tire well is offset and consequently there is limited space to mount fins. 5 fins would be ideal but given the restraints I could only use 3, not ideal but it will be a nice opportunity to test of the look and see if it is something I like.
The goal of this is to "fill" some of the space under the rear bumper to visually make the rear end to look lower. This isn't for winning races or tracking straight on the Bonneville salt flats, this is a experimental and creative aesthetic modification. Time will tell if I like it or not, if I do then I might reconsider finsing a solution to mount 2 more fins.
I wanted to keep this diffuser subtle and tasteful, so many homemade diffusers are over the top, attention-grabbing, stick out excessively, and downright look wildly out of place on most cars, not my cup of tea but to each their own. I matched the angle of the fins to the taper of the bumper the best I could to make this look as possible.
Mounted up with stainless hardware
You can see there is no room on the driverside to add another fin due to the cavity where the oem mufflers were.
I plan to get some black mounting hardware to blend it in better with the fins.
E39 540iT:
- E38 Contour Seats
Old 02-18-2018, 02:32 PM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e60, f25
is it 5 speed yet?
Specializing In Breaking Things Professionally
15486372<-----
Old 02-19-2018, 07:54 AM
ucsbwsr's Avatar
Mein Auto: E61
Originally Posted by Burning2nd View Post
is it 5 speed yet?
Currently slush box but on the horizon a 6-spd swap is highly likely. I love manuals and they seem to boost value given the unique wagon+V8+Manual combo considering BMW never imported them. I have also swapped my E61 from AT to MT so having one swap under my belt should make the second relatively smooth.
Here are some more pics of the diffuser, I like it I don't love it. It fulfills my goals of visually "filling" the space under the rear bumper but I wish there were 5 fins total and they were about 12" longer and reached further towards the rear wheels.
E39 540iT:
- E38 Contour Seats
Old 02-19-2018, 06:24 PM
TickTack TickTack is offline
Mein Auto: 2011 335d, 2002 540iT
GOALS!!!!
I just picked up a 2002 E39 540iT as a "beater" or rather "dog" (we currently have 6 rescue dogs) car. Lot's of great ideas for upgrades. Most of my first upgrades will be to protect the interior of the car from the dogs. Some of them get get pretty fiesty defending their turf/car. One actually smashed a windshield from the inside with his block-head while defending his car (an older car, now deceased)from someone walking by. LOL!!!
Old 02-22-2018, 07:20 AM
jaegerjensen jaegerjensen is offline
Mein Auto: bmw 525 MY 2000
Evan
Looks mint
Sendt fra min HUAWEI VNS-L31 med Tapatalk
Old 02-22-2018, 10:40 PM
BobaTett BobaTett is offline
Mein Auto: '08 535xi / '87 325is
Those bushings look disintegrated...
Giggity though. Sub'd.
Sent from my SM-G930R4 using Tapatalk
08 535xi 6-Spd - JB4 G5 ISO / aFe DCI / ER Charge Pipe / Forge DV
A "Frankenstein" '84 E30 / A labor of love
& '87 E30 Verty (destined to be a truck)
Gone: 02 Audi A4 3.0Q 6-Spd
First Love: '72 3.0CS - Forever missed
Old 02-27-2018, 07:56 AM
ucsbwsr's Avatar
Mein Auto: E61
Originally Posted by TickTack View Post
GOALS!!!!
Wow! 6 dogs! I have my hands full with our Australian Shepard! You should build a custom cargo cover out of a camping tarp or something that would be easy to clean, you could mount some magnets in the cargo area (under the window behind the C-pillar) and put some magnets in the tarp/blanket so it can snap into place and easily be removed for cleaning.
Originally Posted by jaegerjensen View Post
Looks mint
It is getting there.
They certainly felt like it.
E39 540iT:
- E38 Contour Seats
Old 02-27-2018, 08:08 AM
ucsbwsr's Avatar
Mein Auto: E61
Not pictured: I tracked down a Business CD player with the right production year AND the right software to support an AUX-IN. Unfortunately my small Bluetooth card doesn't trigger the Aux in feature and the cable needs to be physically plugged in. Nice to have the Aux working but wish the BT was also functional, cords are so last decade. I also need some more bass, stock sub is a joke.
Through the magic of Craigslist I found a 740i being parted out 30 minutes away from me. It was a manual car with sports package and a VF supercharger on it. Neat build. Anyway, I finally got some beige contour sport seats.
The 740i had ~175,000 miles on it and the driverseat has some typical wear with light cracking and a deformed thigh bolster. Passenger seat is pretty minty. Both cleaned up well with a horse hair brush, some leather cleaner, and elbow grease. Leather was moisturized and buffed.
E39 540iT:
- E38 Contour Seats
Old 03-03-2018, 08:51 AM
ucsbwsr's Avatar
Mein Auto: E61
With my Aux in now working it became wildly apparent the stock subwoofer is almost non-existent and this is NOT OK as I listen to bass music.
I originally was going to mod the stock enclosure to accept a shallow 8" woofer but I reconsidered as I wasn't confidence that would give me the results I was really after so I went down the rabbit hole and ended up what I consider to be a quality sub setup.
Sundown SD-3 10"
Basser E39 Touring Enclosure
JBL MS-A5001
Scosche LOC
Pretty excited to give the Sundown a go. The performance should be pretty impressive and after some poly fill is added to the enclosure the "mimicked" sealed volume should be about perfect at .5 cu/ft.
The JBL MS-A5001 also has some nice features with a strong output; 500w rms at both 4ohm and 2 ohm, integrated DSP, and a small footprint. 500w @ 4ohm should do the Sundown right.
Here are some goodies, sub and box are on the way.
Pre install
LOC installed
Amp installed, I used some hardware to mount it "floating" over the stock amp.
Tapped power from the distribution block, fuse mounted with some 3M VHB, module relocated with zip ties in anticipation for the sub enclosure
Amp wired up
Ran wires parallel with oem wiring
Ready for the sub and enclosure!
E39 540iT:
- E38 Contour Seats
Old 03-03-2018, 01:27 PM
computiNATEor's Avatar
computiNATEor computiNATEor is offline
(oOO\(|||) (|||)/OOo)
Mein Auto: 01 M5
Very nice! Lots of work.
I love how your Australian Shepard seems to be judging you in every shot!
I dig the lighting updates. Do you have more info on the LED fog lights? I want to do something similar (or exactly the same).
I replaced my angel eyes with COB 131mm LED angel eye rings from eBay, and I'm pretty happy. Also did Hella G4/EvoX-R 2.0 bixenons w/ new bulbs, and new lenses and the output is insane. I'd like to do the Hella boosting as well. Did you DIY that?
Nate J. - (oOO\(|||)(|||)/OOo)
Reliable P.O.S. - 1995 Camry V6. 260k mi+.
E39 M5 - TiAg/Schwarz Nappa (M1SW) 07-18-2001 M5 Heritage (BZ99672). 171,000mi and increasing daily.
Prior:
Black Sapphire/Schwarz 03-11-2003 530iA Sport (CK39185). T-boned 03-01-2017 at 155,861mi.
Toledo Blue/Sandbeige 04-25-2002 530iA Sport (CH98032). Sold 11-10-2017 at 147,743mi.
Toledo Blue/Grau 10-29-2001 530i5 Sport (CE92358). Sold 02-01-2019 at 217,600mi.
Old 03-05-2018, 02:35 PM
ucsbwsr's Avatar
Mein Auto: E61
Here is a guide I made on boosting the Hella Gen 3 ballasts, if you do not have the proper tools and skills to modify them and want it done, shoot me a PM and I can assist. The ballasts are incredible.
https://www.facebook.com/VisionAutoL...71348386483544
With your Evo2 projector swap is your driverside cutoff rotated clockwise a bit? I swapped Evo2s in and notices they were crooked. I have since replaced them with some Lexus RX AFS projectors which are low beam only and are not a simple-swap but offer greater width and a better distribution of light.
With the fogs, I don't really have more info than what I posted. You will need a set of fog housings, a pair of 70mm Morimoto universal xb LED fogs, some tools to trim, grind, and make the fog fit inside the housing.
E39 540iT:
- E38 Contour Seats
Old 03-05-2018, 02:49 PM
ucsbwsr's Avatar
Mein Auto: E61
The plan was to simply replace the stock SLS airbags with some new Arnotts but I ran into a snag after swapping the bags where the compressor wasn't responsive and it sent me on a diagnostic spree to finally arrive at the conclusion the compressor bit the dust.
So with the new bags installed the compressor was not activating. I checked fuses, airlines, fittings, sensors, and electrical connectors. All looked good. Although I was getting the "suspension inactive" warning in the cluster I wasn't able to pull a code via INPA and the compressor also wasn't responding to any hand controls.
I dug deeper and tested the relay which was *clicking* with 12v, solenoids were also responsive. I pulled the compressor and bench tested it with my DC power supply by passing the relay and it fired right up and sounded normal. This made me think the relay was the issue, Google told me that although the relay still *clicks* there can be an internal short which limits function. I tracked down a universal 20a relay to swap in, compressor still didn't work but I was hearing an audible hummm from the compressor so I got a replacement and all is well, it turns out the stock relay was also functioning. I assume the compressor has some binding which is limiting it from "getting going." All should be good now.
Saggy rear, blurry photo
New vs Old
Diagnosing
With the new pump installed I took the opportunity to double check for leaks at all fitting junctions with some soapy water. All looked good.
I had some ducting insulation left over from my E61 so I installed some in the rear cargo area for the E39, this should help keep things quiet in general and especially once the sub is installed.
E39 540iT:
- E38 Contour Seats
Old 03-05-2018, 03:01 PM
Mein Auto: 01 M5
Ah, I'd seen that guide before! I think I can DIY it, and I have a spare set of ballasts from my parts car that will be the guinea pigs.
No, my cutoffs are perfect as far as I can tell. I sourced my "Hella G4s" from user blacknight530i on Bimmerforums. They are basically identical to the Evo2s as far as I can tell. Maybe yours was just tweaked a bit? I had to do a good bit of adjustment to the projector/high beam assembly to get the hot spot on the highs lined up with the step/hotspot.
Morimoto, gotcha. I think I can figure the rest out
Prior:
Old 03-06-2018, 09:35 AM
1999KDX528I 1999KDX528I is offline
Mein Auto: 1999 528i
Holy Crap! That looks amazing. if I was half as handy and ambitious as you are my car would look totally different. Nice Work. Can I purchase it when you are done and tired of it?
Old 03-06-2018, 10:13 AM
ucsbwsr's Avatar
Mein Auto: E61
I am an advanced headlight enthusiast and I can confirm there was nothing funny going on with the projectors. I have seen other E39s with the same exact mis-rotation, some but not all so I figure depending on the production year housings might have different mounting posts. I know that some E39s can be opened with prying the lenses off and others can't. Anyway, not a big deal, just curious as I like to collect data on stuff like that.
When it comes time to sell it might have a 6spd manual in it but either way I can guarantee it will be well cared for.
E39 540iT:
- E38 Contour Seats
