Auxiliary water pump on e36!? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 05-10-2018, 01:27 PM
323ti 323ti is offline
Mein Auto:
Hi! I have a 323ti - technically same as 323i, so it is a m52. Someone of the previous owners has run extra wiring and installed a auxiliary water pump - looks something like 64118390063, but metal not plastic.
As far as I know e36's should not have this.
My question is why would anyone add this and can I remove it - because it is leaking.
Old 05-10-2018, 02:06 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
Wow, that's really odd. Where did they install the auxiliary pump?
As long as your OEM pump is in place and working, you can eliminate the extra one. The only reason I can think of for the extra pump is that they had problems with the regular one. Maybe had overheating problems and thought a second pump would help with cooling.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 05-10-2018, 02:19 PM
Mein Auto:
Thank you, glad to be here, its my first BMW.
In the cooling system it is located right before the heater control valve or whatever its called - 64118375443.
I live in a cold climate, so maybe it has something to do with interior heating?
Old 05-11-2018, 06:54 AM
bluptgm3 bluptgm3 is offline
Mein Auto: 99M32
That is definitely not an E36 part.
If you have a cooling / heating issue, that will have to be addressed.
Old 05-11-2018, 06:55 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
BMWCCA HPDE Instructor
Mein Auto: 1998 BMW 328is
Can you post a photo so we can see it? I'm curious to see what handiwork the previous owner has done.
1998 BMW 328is
1966 Pontiac GTO
Old 05-11-2018, 07:14 AM
Mein Auto:
No issues with cooling or heating. The pump just started leaking and that's when I found out that it should not even be there.
Ill try to get some pics of the wiring later.
Old 05-14-2018, 04:01 AM
M-technik-3 M-technik-3 is offline
Mein Auto: 88 M3x2 86 330i 4 e36's
Ti's are not known for great heat and if you live in a cold ie Scandinavia area like area it might have been installed for personal comfort.
Old 05-16-2019, 10:36 AM
Mein Auto:
Hey everyone. So I have finally removed this ''tumor'' that some past owner mounted on my ti and took some pics of the setup. Was actually a Mercedes pump.
The power came from front foglight wires Foglights itself weren't mounted on the car and I had to buy new connectors from Bmw to get the foglights eventually functional.
Offtopic: Car itself hasn't run since march of last year, because its had sort of a rebuild. All the typical rust spots are fixed, complete rear end rebuild, new bushings, new brakes, new suspension parts, new clutch etc. etc
Last part I am doing right now is replacing all the typical wear parts on the engine + complete new cooling system. So thats why I am posting this so late.
After this the car will go to the paintshop and will get a full respray.
Hope you are all enjoying a wonderful spring!
ID:	852149   Click image for larger version
ID:	852151   Click image for larger version
ID:	852153   Click image for larger version
Old 05-16-2019, 10:32 PM
D'oh, You Kids!
That's one of the most bizarre kludges I've ever seen. I'm glad you're putting it right.
Quotes to live by:
BMW-CCA #441426
