Having trouble removing the alternator, ASAP... - Bimmerfest - BMW Forums
Old 05-25-2018, 12:57 PM
Semerka Semerka is offline
Mein Auto: 2014 435, 2007 X5
Hi guys. My 2007 X5 4.8i is our winter vehicle. So I am fixing it these days. I got an oil leak through oil thermostat gasket, so I am trying to change it. The procedure requires removing the alternator. Upon removal of all things like braces, wires, bolts etc. I have the alternator ready to go. But it won't... It moved about 12 mm (looking at the Top bolt hole I can see most of it). But it took too much effort and a pry bar to get there. I never heard anyone on Youtube mentioning this problem (hard to remove / install alternator once it is unbolted). Does anyone know?
Old 05-25-2018, 01:02 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Removing alternator. Www.NewTIS.info
newTIS.infobeta
Home / BMW E70 X5 4.8i SAV / Repair Manuals and Technical Data / 12 Engine electrical system / 12 31 Alternator with Drive and Mounting Parts / 12 31 020
Removing and installing or replacing alternator (N62)
https://www.newtis.info/tisv2/a/en/e...-parts/GUMKp5R
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 05-25-2018, 01:27 PM
Thank you Doug. I haven't removed the passive tensioner, nor the refrigerant line holder yet. The thing is that the alternator doesn't drop off. Not that I don't have any room to pull it out, but it is just like stuck on the engine.
Old 05-25-2018, 01:40 PM
Nuclear engineer
Did ya whack it gently - apply mechanical hysteresis - to break corrosion alternator frame to engine block?
Old 05-25-2018, 01:48 PM
Yes I did wack it with a 16 oz. hammer through a 2 x 2 piece of wood. I don't see any corrosion marks on the engine though. Of course the corrosion may be on the alternator mounting fork itself.
Old 05-25-2018, 01:52 PM
ArgentoCarNut ArgentoCarNut is online now
What was that?
Mein Auto: 05 M3, '13 TLC, '11X5 35i
Bigger hammer?
Old 05-25-2018, 01:55 PM
I am a bit scared, but of course have considered that. Have you had this problem and applied this solution?
Old 05-25-2018, 02:05 PM
Nuclear engineer
Only when I was sure that that was the only impediment to the piece coming loose.
More gentle that a whack is an overnight soak in Coca-Cola dilute phosphoric acid (Coca-Cola Merchandise No. 4) solution - 2 pH. Soak a rag in coke and wrap it where it will do the most good.
Old 05-25-2018, 02:21 PM
giaka giaka is offline
Mein Auto: 2009 X5 3.0
Can you post a pic of your alternator as it sits now?
Old 05-25-2018, 02:30 PM
Thanks, Doug. I don't think it is possible to wrap a soaked rag, but I will try. I believe that vinegar has the same acidity as Coca Cola, so I may as well use it?
Old 05-25-2018, 02:33 PM
What was that?
If located in US, try this
Old 05-25-2018, 02:34 PM
What was that?
Same issue. Different BMW (and Iíll admit, a couple too many brewskis).
Old 05-25-2018, 02:42 PM
Nuclear engineer
Absolutely. 1 M acetic acid is 2.4 pH. 1 M is about the concentration of household vinegar.
Old 05-25-2018, 02:47 PM
acoste's Avatar
acoste acoste is online now
Mein Auto: 2010 550i MT
https://www.pelicanparts.com/techart...eplacement.htm
2010 BMW 550i MT
2003 BMW 325i @216k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 05-25-2018, 02:52 PM
Sure. Just don't have a heart attack seeing it. The oil is leaking like crazy
ID:	797436   Click image for larger version
Old 05-25-2018, 03:03 PM
Nuclear engineer
I don't see any corrosion. It looks to me like it's cocked on the very tight parallel surfaces. I think judicious tapping and wriggling to get the alternator square on the mounting surfaces and it ought'a slide off.
Old 05-25-2018, 03:16 PM
acoste's Avatar
+1, needs to get off evenly
I filed mine a bit before putting it back so it was easier. Otherwise it is even harder to put back than removing since there is no leverage point.
2010 BMW 550i MT
Old 05-25-2018, 03:19 PM
Thank you guys all. I really liked all the suggestions, and I think Doug ruled out the corrosion issue. I also like the Pelican suggestion where to put the pry bar to move the thing. If I can move it up than I can tap it down later, and so on. I really don't like the bushing on the back side of the alternator fork
Old 05-25-2018, 03:22 PM
What was that?
This
Old 05-25-2018, 03:42 PM
Okay then. You guys have been a great help for me. Maybe you can suggest something on the following?
1. This infamous oil thermostat gasket. Should I use a Permatex oil-resistant silicone on a new gasket to have it done once and for all?
2. I am an engineer, but not electrical. When I get the alternator out, what is the best way to clean it without disassembly not worrying about its gut contamination?
Old 05-26-2018, 12:54 PM
LOL Yeah thats kinda nasty . Hope you get it out.
Old 05-27-2018, 01:58 PM
deroy deroy is offline
Mein Auto: X5 e70 4.8
Op are you absolutely positively sure the alternator has to come off? I think the x5 v8 has the alternator bolted to the engine block and the oil gasket thing is a completely separate part and may be better accessible from below or through the wheel well
http://www.realoem.com/bmw/enUS/show...diagId=11_3990
Verzonden vanaf mijn iPhone met Bimmerfest
Old 05-27-2018, 02:20 PM
Yes, I am absolutely sure that N62 has the oil thermostat cover hidden under the alternator. All videos say that, here is one.
Old 05-27-2018, 02:30 PM
Yeah saw that one.
But given your troubles; removing a wheel and some plastic may well be worth the try.
Old 05-27-2018, 02:40 PM
Yeah saw that one.
Well, what I did I drained the oil sitting the truck on the ramps. It is very difficult for me now to remove the left ramp and put the vehicle on the stand to remove the tire. Besides, I still can't see any access to the alternator from the wheel side yet. It sits right against the frame. Not the plastic cover
4.8i, alternator, e70, gasket, leak, n62 oil leak, oil thermostat, x5
