prospect M3 purchase but had emissions issues - Bimmerfest - BMW Forums
E46 M3 (2001-2006)
Old 07-05-2018, 07:53 PM
ciback ciback is offline
Mein Auto: WRX
I am in the market for a E46 M3 and found a promising option. The only thing that stands out is that the car failed emissions test 4 times in the space of 4 months in Texas around the 87000 mile mark. Is that a red flag? I am looking for an M3 which is not be modified
Old 07-06-2018, 08:30 AM
geminiys geminiys is offline
Mein Auto: F10 5353xi, E46 M3
Failing emission could be a lot different things. In most part the issues is with OBDII emission monitors not been ready will cause Emission Failure. These issues are addressed by replacing part(s) at fault, clearing CEL if on, and driving for ~60 miles. You are done. Some monitors, especially Secondary Air Pump is very hard to diagnose, as if Pump is working and CEL is off the cause is unknown. In this case mechanic needs to find where the problem is. Most of the time it's the Secondary Air Pump Valve that blocks the airflow during cold starts. To diagnose this issue one can monitor O2 sensor voltage during Cold starts and compare in few minutes later. If no change in voltage swings, most likely the valve. The "lazy" O2 sensors can cause similar emission failures. Catalytic Converters will definitely cause emission failures too. Another one is if engine temp never reaches proper operating temp, will cause emission failures. This one could be due to incorrect (temperature) thermostat installed. Get an understanding of what exactly failed and do some research.
Current Rides:
2013 535XDrive, 110k Miles
2005 M3, 77k Miles
1997 328is, 335k Miles - RETIRED
1998 Mercedes ML320, 200k Miles - SOLD
2005 Volvo XC70, 160k Miles
2018 Audi Q5, 100 Miles
Old 07-22-2018, 07:48 AM
1bad540's Avatar
1bad540 1bad540 is online now
Id check what failed, some of these cars were recalled due to non communication w the obd2. Mine was.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 02-16-2019, 05:42 PM
Mein Auto: WRX
Thanks for the info. still in the market and am seeing that come up on multiple prospects, both of them are 2002. Having a PPI performed on one next week
Old 02-16-2019, 06:00 PM
Autoputzer Autoputzer is online now
Mein Auto: 2014 535i + 2018 X3 30i
The early 2002's had the exploding engines. Make sure any 2002 you look at had the recall that changed out the connecting rod bearings.
Old 02-17-2019, 01:20 PM
Mein Auto: WRX
I am concerned about that, was not on the carfax. I will appreciate any advice someone might have. I asked for a quote on a compression test and leak down test during the PPI but they wanted $250 each for the test. Did not think it was worth it unless they see something that makes it necessary
Old 02-17-2019, 01:34 PM
Mein Auto: WRX
It has 117,000 miles on it. Supposedly no engine mods and not tracked
