Comfort Access - tailgate/hatch won't open when pressing pad on rear hatch - Bimmerfest - BMW Forums
Old 10-29-2018, 05:32 AM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
Question Comfort Access - tailgate/hatch won't open when pressing pad on rear hatch
2013 X1 MSport
The hatch opens, pressing the pad on the hatch IF the car is unlocked - it also opens (unlocks) if I use the FOB button or the button inside the vehicle. BUT if the car is locked and I am standing at the rear hatch with the FOB (new FOB batteries recently installed) pressing and holding the pad on the hatch exterior won't unlatch (open) the tailgate. The pressure switchpad functions 'correctly' to open the hatch if the car is unlocked.
I'm suspecting the touchpad/switch on the rear hatch has failed - no matter how hard I press or how long I hold it the hatch/tailgate doesn't unlatch and I have to use the FOB to unlock-open the rear hatch/tailgate.
Has anyone experienced this? Anyone replaced the switchpad? Or the CA unit at on the hatch/tailgate?? Looking at the TIS makes it look like an easy DIY and the part is available on-line of less than $40 but if it's something that can be done by reinitializing the FOBs or if it requires replacement of Comfort Access modules that would be something to rethink.
ALL other CA functions are OK! No RF interference going on - I've tested this and used the hatch access without issue as long as we've owned the X1.
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive | '13 X1 MSport | '98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
Old 10-29-2018, 12:11 PM
mreric mreric is offline
Mein Auto: 2015 BMW X1 Xdrive E84
try inserting the keybob into the keyfob slot. start the vehicle. turn off and try again. this sometimes reset the keyfob system
Old 10-29-2018, 03:10 PM
Exclamation FOB is now back on the job :-)
I had read there was a process using the key to unlock the car front door - start the car - etc ... but didn't have the opp'ty to try it. BUT I just tried your recommendation and the tailgate now unlocks, as it had previously, with the FOB.
Thanks for the tip :-)
Old 10-29-2018, 03:50 PM
insert the key from time to time to keep it trouble free
Old 10-30-2018, 07:20 AM
Talking CA FOB Stuff
Thanks for the advice; I've had CA on my BMWs going way back to my e60 2007 530xi and never had a FOB issue.
But as the old saying goes, "There's always a first time!" ... so I guess this was mine :-)
Thanks again!
Old 10-30-2018, 08:45 PM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
Doesn't inserting the key also charge the key battery?
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 10-31-2018, 04:18 AM
mcdanielvzw mcdanielvzw is offline
Mein Auto: BMW X1 xDrive35i
Not on the CA system. It has a replaceable battery. Non-CA systems charge a key fob.
Old 10-31-2018, 03:04 PM
Red face Ca
Old 04-23-2019, 09:08 AM
Rear hatch acting up again - opens OK with CA if the X1 is unlocked but not separately when the X1 is locked. I'll double check the FOB batteries to see if they're at full voltage but I did replace the batteries about a year ago. It's not a big deal to unlock the car to unlock the car (using CA) open the hatch so I don't think it's a mechanical issue. I did use the FOB inserted in the slot to start & restart it 2x but that didn't resolve the problem. More later after I check/replace FOB batteries.
UPDATE: Replaced FOB batteries ... rear hatch w/CA back in working order.
