Considering buying a 2001 M3, not sure about price - Bimmerfest - BMW Forums
E46 M3 (2001-2006)
Old 02-21-2019, 05:02 PM
gillzj00 gillzj00 is offline
Mein Auto: 2011 X5 35i Premium
This M3 is at a dealership near me in Colorado:
https://www.schompbmw.com/inventory/...br934x1ex20615
Price seems a little high. Would an SMG be more or less expensive? I kind of want a full manual.
It has the xenon headlights, 10 piece speaker system, and cold weather package. I am not sure if it being a convertible is a pro or con for me.
I've owned an N52 X3 and currently have an N55 X5 and have worked on these cars with the help of ISTA+ and newtis.info I read that the S54 is basically a fancier N54 which is the engine the N52 was based on.
What're your thoughts?
Thanks guy!
Old 02-21-2019, 05:29 PM
Autoputzer Autoputzer is offline
Mein Auto: 2014 535i + 2018 X3 30i
I sold a 2002 M3 coupe with 115k miles for the KBB price, about $9500, five years ago. I had 200 to 300 inquires after the first one bought it. So, I should have asked more for the car. So, $14k from a dealer doesn't sound unreasonable at first glance. With a car that old, mileage is a stronger factor than age in determining the car's value.
Back when I bought mine new, there was a two year waiting list for coupes and almost no waiting list for convertibles. I suspect that coupes are now more desirable and more expensive, because they're lighter, stiffer, and hold up much better in rollover crash. You'd need to plug it into KBB.com or Edmonds.com. I never really understood high-performance convertibles. Porsche didn't build a 911 convertible until 1983, and then it was mainly for the California, Rodeo Drive market.
Manuals are much preferred over SMG II's. So, they're more expensive. The SMG II is just a conventional manual transmission with a computer controlled clutch, shifting, and rev' matching. It behaves more like a conventional automatic, with slower shifting than a DCT on later M cars. I don't think SMG II was even offered on the 2001 E46 M3's. 2001's were only in production about seven months.
S54's big difference is that they have solid lifters that need adjustment about every 25k miles, and you need a kit (shim tray) and tools to do it.
The early S54's were subject to two recalls. The first one changed the oil pump and connecting rod bearings. The second one changed the connecting rod bearings again. Make sure that one has had both.
Old 02-21-2019, 06:51 PM
Thanks for your $.02.
I too am generally not a big fan of convertibles. My fiance wants one and the summers here are nice so I could see it being fun.
I've never heard of adjusting lifters before, especially at that interval. The furthest I've got into an engine is a valve cover replacement so I am not sure if I could DIY that myself. Does the head need to be removed? What would symptoms of the lifters needing adjustment be?
This vehicle has just over 88k miles so it's relatively low for the year.
-- Edit --
Just watched a video on measuring and replacing the valve shims, doesn't seem like a big deal. Do you need to adjust the timing when you do this too, that wasn't covered in the video? It looks like to have a pro do the job it's about $450 which every 2 years isn't a big deal.
I've read in the N54 the DISA valves could break and get sucked into the intake, does that happen in this engine?
Old 02-21-2019, 11:57 PM
If the cam-tappet clearance is too much, it causes scoring of the lobe and follower.
If the cam-tapped clearance is too little (when cold), there could be interference when the engine's hot, and the valves will not close completely. This causes a loss in compression and also bathes the valves in combustion gasses, causing them to overheat and "burn."
S54's have solid (not hydraulic, self-adjusting) lifters because of the engine's "radical" or long duration cam lobe profile that holds the valve fully open longer than on a normal engine. That means that the opening and closing motions must occur faster. Throw in the S54's 7900 RPM redline, and hydraulic lifters couldn't keep up.
Old 03-31-2019, 08:05 AM
1bad540's Avatar
1bad540 1bad540 is offline
In Ny, thats cheap for that car.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 03-31-2019, 01:41 PM
jiveturky1 jiveturky1 is offline
Mein Auto: 09 335xi 6MT, 05 M3 6MT
It's a good price.
Old 04-08-2019, 05:56 PM
targaone targaone is offline
Mein Auto:
Looks very nice to me.
Similar Threads
New Build - Constructive criticism very much welcomed dzhou102684 F80/F82/F83 M3 and M4 (2015 - Current) 68 12-30-2018 08:51 PM
2018 M3 ED Price Check mini4m3 European Delivery 9 03-02-2018 08:09 AM
Bimmerfest Caravan Route, in case anyone missed it MarcusSanDiego General BMW Questions 19 05-02-2007 09:55 PM
Buying a used M3 mkell 1M & M2 1 08-02-2004 09:42 AM
Trade in advice.. 2001 Z3 for '99 M3. daftsynth General BMW Questions 0 11-01-2002 01:06 PM
