How do you repair the cracked hard rubber around the windshield and back glass - Bimmerfest - BMW Forums
Old 03-01-2019, 06:13 AM
Zseabass Zseabass is offline
Mein Auto:
My 2002 540i is having a hard time since I neglected it for the past 8 months, I have been tackling the issues one by one, I replaced the battery (fixed quite a few electrical gremlins), resealed the vapor barriers in the rear doors and shop vac'd a'll the water once the half inch of ice melted and pulled the rear seat out and pulled the carpet up and let it sit over night in a garage with the heat turned up to 90 on the thermostat and even added a kerosene salamander for a bit. Today I'm replacing the front passenger side window regulator and powerflex bushings for my thrust arms are on the way.........So the next project i want to tackle is the ****ty crumbling rubber around the windshield and back glass.....is it something that can be DIY or is it smarter to have a professional do it, I'm reasonably gifted at auto repair but have no experience with glass.....What's it gonna take, what's it gonna cost if I were to do it myself and what would it cost to take it to a shop......Thanks guys
Old 03-01-2019, 06:16 AM
528iAut 528iAut is offline
Mein Auto: 1996 528i
The rubber strip? Just replace it.
https://www.bimmerfest.com/forums/sh...d.php?t=294623
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 03-01-2019, 06:29 AM
wjg22 wjg22 is offline
Mein Auto: E39 540i sport
I used that video that 528iAut posted above as a guide and it's not difficult. I did, however, incorrectly order the wrong gasket for the windshield (protective glazing vs not?), so make sure that you get the correct pieces.
Old 03-01-2019, 06:46 AM
bmw blue's Avatar
bmw blue bmw blue is online now
Mein Auto: 2000 BMW 528i Steptronic
What exactly do you mean the correct pieces. Are you saying there are 2 different part numbers for the front glass trim cover? 1 for if you have never taken the windshield off and 1 for if your windshield has been replaced and the extra sealer prevents correct installation of the weather seal, please explain.
Beisan Vanos Repair, EMP Stewart Water Pump, Aluminum Water Pump Pulley, Behr Electric Fan, Sachs Fan clutch,
18pc Lemforder Suspension Kit w/Koni Sports+H&R Springs,
E46 Intake Boot W/AFE Dry Air Filter, Conforti Shark Injector,
Liqui Moly Leichtlauf High Tech 5W40 Motor Oil, Pentosin Full Synthetic Transmission Fluid and 75-90 Motul Full Synthetic Differential Oil.
Michelin Pilot Sports (summer), Continental DWS (winter).
190,500 miles and counting.
Old 03-01-2019, 07:00 AM
I ordered this guy: https://www.fcpeuro.com/products/bmw...172745#fitment (Part #:BMW-51318172745), which is for E39's with option code S357A (protective glazing)
It wouldn't sit flush on the sides of the glass and wanted to pop out.
This was the correct seal [for me]: https://www.fcpeuro.com/products/bmw...159784#fitment (Part #:BMW-51318159784), for E39's without "protective glazing."
Old 03-01-2019, 09:54 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
If that is the original seal or windshield it will just pull right out with minimal effort. It is just a noise reduction feature and offers no water sealing functions at all.
When installing the front trim, my suggestion is that you ensure you get the top, horizontal run correctly placed. Make sure both ends sit flush right at the corners. After that getting the sides to slide into place is easy.
2002 530i
Old 03-01-2019, 11:53 AM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
a 1/4" wooden dowel sharpened to a blunt flat (screwdriver like) point and a spray bottle of water with a bit of dish soap in it aids the installation a lot.
99 528i 5sp sport
be alert...the world needs more lerts
Old 03-01-2019, 04:41 PM
monkeyman_69 monkeyman_69 is offline
Mein Auto: F10 535D X 2015
It's a relatively simply DIY. The parts are funny looking. 3 pieces of rubber that are connected by a hidden fitting that allows it to bend (the corners of the windows) but not separate. I found the sides to be easy, it was the top along the roofline that was harder. Soap (or other lube) and any kind of dull push tool works. If you start one on corner you may get all the way to the other corner find out you are short. So pull it back out, stretch it more, and reinstall. (A buddy may help here.) I found that slightly pounding on it helped it go in (heel of your hands works, but it'll hurt later). Just don't pound parallel to the windshield. Pound parallel to the roof instead. Otherwise, if your hand dips low, you'll hit the glass directly and it's weakest on its edges. Ask me how I know.
+1 to crazy4trains and mattmar1
Old 03-01-2019, 05:49 PM
bmw blue's Avatar
If your windshield has been replaced it is impossible to get that windshield trim back
on correctly because of the 3M adhesive that is used oozes out and makes it not doable
without fashioning a tool to get under the lip of the windshield and slicing the goo away perfectly.
I went through this in 2012 replacing that trim piece, never got it to fit correctly.
But I knew about that going into the repair (windshield possibly having been replaced by the PO)
I have a new trim piece thats been sitting around for 7 years as I bought yet another after my 1st failed attempt.
Probably gonna have to take the windshield off to get it right.
Old 03-02-2019, 05:46 AM
SamD SamD is offline
Learning Every Day
Mein Auto: 01 540i Sport 6-spd
In replacing my trim around the windshield and rear glass, I considered this: is it possible that BMW installed the front and rear glass with the trim already in place on the glass? The way it finds a home in the glass seal that's nearly impossible to get re-seated with a new part leads me to believe this might be a possibility. The other thing I considered is that taking the glass out seems to be the only way to get new trim to fit correctly.....
'01 540i-6 Sport
...more fun with DSC off...
Old 03-02-2019, 05:48 AM
Learning Every Day
Can you describe the "protective glazing"? I did not know there were differences in the glass seal...
'01 540i-6 Sport
Old 03-02-2019, 05:53 AM
Learning Every Day
Rear quarter glass rubber
If anyone has any earth-shattering suggestions for replacing/repairing the quarter glass rubber, please share! That is the one piece of crumbling rubber that I can't seem to figure out what to do with...... :-(
'01 540i-6 Sport
Old 03-02-2019, 06:33 AM
bmw blue's Avatar
https://www.bimmerfest.com/forums/sh....php?p=9128770
Old 03-02-2019, 08:43 AM
Learning Every Day
That's exactly what I needed, though it looks like a complete PITA but do-able :-) Thank you!
'01 540i-6 Sport
Old 03-04-2019, 07:36 AM
Apparently it isn't very common. I don't know much about it, but I dug this up from another thread:
Originally Posted by Qsilver7 View Post
If you had the theft-proof glazing (windows)...you probably wouldn't be questioning yourself as to IF you had them. If/when you see this option...it is obvious that the windows are not the usual ones that you see. They are thicker and have extra lamination etc.
The laminated glass developed for BMW Protective Glazing consists of two layers of glass with a layer of polycarbonate in between. The entire "sandwich" is then embedded in TPU film. It measures 9 millimeters across, and if you've seen the "insulating glass" in the 750iL...this theft-inhibiting glass is exactly as thick as the insulating glass in those models.
I also believe that this glass (glazing) option could only be had with a METAL sunroof (the glass moonroof couldn't be ordered with the protective glass)...and the REAR windows would also be fixed (unable to roll them down).
So if you have a metal sunroof, your rear windows don't roll down, and the glass is thicker than what you've seen on other e39s...then you DO have the "protective glazing"....if not...you have the regular-ol-common windows like the rest of us.
Old 03-08-2019, 04:23 PM
Learning Every Day
Sorry to drop the ball on this thread. Thank you for the clarification! I'm eyeing the new rubber at FCP Euro and will likely order both sides this spring. I've got the tools and the urethane sealant, and most importantly I think I can handle this job... :-)
'01 540i-6 Sport
Old 03-09-2019, 07:53 AM
Where are you using the urethane sealant? To my recollection the seals do not require any sealant. They are merely a friction fit.
2002 530i
Old 03-09-2019, 08:00 AM
Learning Every Day
Friction fit? No, they are sealed in like the front and rear glass with a urethane sealant that must be cut just to get the glass out, then re-sealed to secure it in place. There are a few videos, in this thread I think, of the process...
'01 540i-6 Sport
Old 03-09-2019, 10:43 AM
mattmar1's Avatar
Wingnut
what he said ^^^^...no sealant is needed unless you are removing the glass windshields...then the sealant is used for the glass only, not the outer seal piece. to remove, pull up a spot, remove, reverse for new seal using a mixture of water and dish soap in a spray bottle and a wooden dowel with a blunt tip. when i had my car repainted a few years ago, some slow leak there used sealant on the trim pieces, and hadda remove the seals, clean everything up, and install new ones. was a PITA. yeah shoulda had them do it, but i made them supply the new seals and did it myself. the trim piece is more or less cosmetic, water sealing is done by the windshield.
99 528i 5sp sport
Old 03-09-2019, 11:02 AM
Learning Every Day
Hold-up! I see what's happened here: I got the thread off topic by raising a question about quarter glass rubber replacement. The conversation since then has been mostly about those quarter glass rubber seals, not the trim around the front (windshield) and rear (just ahead of the trunk) glass.
I'm replacing the rubber seals around each piece of quarter glass, and I'm 99.9% certain those require sealant to hold them in place. Correct?
'01 540i-6 Sport
Old 03-09-2019, 12:09 PM
mattmar1's Avatar
Wingnut
oops..sorry sam. i dunno on the quarter glass, ive never dealt with them
99 528i 5sp sport
Old 09-07-2019, 06:07 AM
RoryLeach RoryLeach is offline
Mein Auto: Bmw X1
I never thought of doing windshield replacement but after seeing such great pictures i am looking to replace the old torn one.
Similar Threads
Object hit and cracked windshield. Hookster57 F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 68 05-31-2019 05:27 PM
Question about back glass molding install springs37923 E60 / E61 (2004 - 2010) 6 01-11-2019 12:32 AM
2017 740i Windshield cracked RajDotKapoor 7 Series - G11 / G12 (2016 - current) 18 08-07-2018 07:25 AM
Windshield repair and OEM windshields rwg 3 Series & 4 Series 2 09-16-2002 02:12 PM
