Passenger side a pillar water leak?? - Bimmerfest - BMW Forums
E46 M3 (2001-2006)
Old 03-14-2019, 02:15 PM
Kota530i's Avatar
Kota530i Kota530i is offline
Dakota93
Mein Auto: 2003 BMW 530i sport
Just got this car 2 days ago and got rain today noticed this leak explains why the floor was wetClick image for larger version
Old 03-16-2019, 08:27 AM
tkhaus tkhaus is offline
Mein Auto: 2008 328xi Wagon
I havenít seen that particular leak, but I had an E60 that was leaking on the inside of the pillars and pooling under the seats. The issue was the drain plugs at each corner of the roof. They fill with debris will become clogged. The rear ones are up inside the wheel well, the fronts I believe are at the bottom of the pillar. Google it and youíll see where located. The sunroof is not sealed by design, water drains around it and down through the pillars. Def a good place to start.
Old 03-17-2019, 10:11 PM
Kota530i's Avatar
Dakota93
Yea it was the drain tube from sunroof, the little rubber boot came off from the car. Reattached it and threw some rtv around it so it doesnít come off again, poured water down it and no more leaks
Similar Threads
Rain water inside driver's side door scottalexander E60 / E61 (2004 - 2010) 2 12-17-2018 06:52 PM
Bent sunroof , interior water leak cperrone5 F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 31 10-03-2018 09:04 AM
X-5 GPS issue after air-bag recall (Passenger Side) willy5079 X5 E70 (2007 - 2013) 2 08-25-2018 09:22 PM
Coolant leak - is it water pump? Takkie X3 E83 (2004 - 2010) 44 04-12-2018 07:57 PM
