Active Autowerke F8x M3 M4 Midpipe Step By Step Install + Sound Clips - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 03-18-2019, 08:55 AM
[email protected] mike@x-ph.com is offline
Mein Auto: FBO 07 e92 335i
00:00 - 01:35 Benefits of upgrading the midpipe
01:35 - 02:40 Step by step install
02:40 - 03:23 Sound Clips
The Active Autowerke F8X Mid Pipe was specifically designed to eliminate the highly restrictive nature of the OEM F80 M3 and F82 M4 mid pipe. The stock dual pipe design gives the engine a raspy tone and is very restrictive with 2 cats and a resonator.
After much research and testing, Active Autowerke discovered that there is tremendous benefit to be gained by replacing the stock pipe with a 3.5” single high flow midpipe both with power and sound. The next challenge was making a large 3.5" pipe (needed for optimum performance ) fit without ground clearance issues - thus the oval pipe.
The key features of this upgrade are:
• Improved performance from less back pressure
• Deeper & throatier exhaust note
• Less restrictive, more free flowing
• Lighter weight than factory system
• Allows quicker turbo spool
• Increased low end and mid-range power
• And eliminates cheap “weed-eater” sound from the factory exhaust.
Active Autowerke Dynoed their shop M4 and it showed gains of 18 horse power & 30 pounds of torque with just the midpipe upgrade.
Let’s now go through the install process:
Remove stock midpipe
The first step when installing is to remove the stock midpipe and the process time takes 15 minutes. Start by removing the brace, then disconnect the midpipe from the downpipe, then cut from the exhaust side and remove the hangers.
Install Active Autowerke Midpipe
First we will install the long pipe by attaching the hanger , and connecting the midpipe from the downpipe side . Then get one of the small pipes, and connect it to the midpipe then connect the hanger . You’ll do the same for the other side , and once everything is installed correctly, you’ll tighten the connections
Once installed the midpipe gives a noticeable difference in sound and power. The Exhaust tone is now much cleaner without any rasp, it also opens up after 3500 RPM and gives the M3 / M4 a deep and aggressive sound without being obnoxious.
Old 07-25-2019, 11:03 AM
Active Autowerke Downpipe + Midpipe Install
Similar Threads
OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED** [email protected] F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 2 03-12-2018 09:56 AM
OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED** [email protected] F22 / F23 2 Series (2014 - Current) 1 03-12-2018 09:56 AM
OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED* [email protected] F12 / F13 (2012 - 2018) 2 03-04-2018 12:35 PM
OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED*** [email protected] F10 / F11 (2011 - 2016) 0 02-23-2018 10:06 AM
