Service Engine Soon - Bimmerfest - BMW Forums
Old 03-25-2019, 04:53 PM
p598738 p598738 is offline
Mein Auto: Z4 2,5 and 3.0
Service Engine Soon
2005 2.5 75K miles.
Just replaced the valve cover gasket and plugs.
Not soon after the above I am getting 'Service Engine Soon' warning light. It is solid and does not blink. The owners manual says that 'it indicates a fault in the emission-related electronic systems'.
Might it be related to the valve cover replacement ? Is there a fault code stored ? Must I really take the car to BMW or can Auto Zone read the code for me ?
Thanks for your thoughts and advice.
Old 03-25-2019, 06:38 PM
BostonB6's Avatar
BostonB6 BostonB6 is offline
Mein Auto: 2005 E85 Z4 3.0
Autozone should be able to read the code. Any chance you cracked the cover when removing it?
Old 03-26-2019, 12:13 AM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Does the car run ok otherwise? I would start by double checking the coil to plug connectors, sometimes it takes a firm push to get them to pop onto the plugs. Also recheck any other electric connections you may have disturbed, or if there is a hose you left off or that got cracked in process. If you find the problem, it may need a few start cycles before SES light goes out. If you don't, Autozone scanner is worth a shot but is likely generic OBDII and not specific to BMW.
[SIGPIC]
Old 03-26-2019, 03:59 AM
Could have gotton cracked. BMW dealership did the job.
Old 03-26-2019, 04:05 AM
The car is running fine. My concern is that the problem could get worse. As I said above, I didn't do the job. the dealership did it.
I guess I will have them look at it.
Old 03-26-2019, 07:46 AM
jman1975 jman1975 is offline
Mein Auto: ...
Completed this exact same project (VCG & spark plugs) last fall; reassembled everything and had no issues. Like others are saying, check for cracks. I -did- chip my cover trying to remove it, but nothing detrimental has come from it, just used a little extra gasket sealer on that particular corner.
Curious to know what code is being thrown when you find out!
the stable:
2003 BMW Z4 3.0i
2008 Hummer H3 Alpha
2015 Mitsubishi Outlander Sport 2.0
Old 03-26-2019, 09:30 AM
Sorry-- you did mention that. Definitely take it back, they probably left something undone.
[SIGPIC]
Old 03-26-2019, 11:35 AM
Codes:
P1449 Diagnostic Module Tank Leakage (DM-TL) Pump Current Too High
P1447 Diagnostic Module Tank Leakage (DM-TL) Pump Current Too High During Switching Solenoid Test
Not sure what this is all about.
Old 03-27-2019, 07:47 AM
Mein Auto: ...
Codes:
saw this older thread regarding P1449 -> https://www.bimmerfest.com/forums/sh...d.php?t=794694
the stable:
2003 BMW Z4 3.0i
Old 04-23-2019, 06:59 AM
Codes:
Guess what !!! Procrastinated long enough and the SES light went off. No explanation.
Anyone else have such an experience ??
service engine soon fault code
Similar Threads
Damaged Engine - Faulty Oil Change - Engine Oil Cap insert removed. justinz X5 E70 (2007 - 2013) 7 07-04-2018 08:36 AM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
Product review: Griot's Engine cleaner kit(m) The HACK The Detail Department 20 01-08-2002 07:56 PM
