Leaked coolant while stored in underground parking - Bimmerfest - BMW Forums
E46 M3 (2001-2006)
Old 04-07-2019, 06:25 PM
deanjobs deanjobs is offline
Mein Auto: 1999 328i Convertible
So I rambled on a bit so TLDR: left car stored, has a big puddle of coolant, where should I start. also is there a fuse that would cause codes for all 4 o2 sensors.
Hello, So I bought my 2002 M3 last summer in California. I drove it back to Utah stopping in Vegas to have the vanos rebuilt because it wasn't sounding right to me and I didn't want to take any risks. After that the car ran great until I put it in my underground parking to be stored over the winter. I went down and checked on it every once in a while starting it for a bit to make sure everything was fine. When I went down to start it most recently I noticed a big puddle under the front of the car under the passenger side. Upon further inspection I found that all the coolant had leaked out. My first thought was with it being a California car the previous owner used water instead of coolant and it froze. I did however have the shop do a full coolant flush and I confirmed they did it by contacting the shop that did the work, and I believe them as they are a pretty reputable shop. I filled the tank with water just to see if it would leak out and after running it for a bit then leaving it for a few days not much had leaked out. Today I drove the car around the garage for a bit and noticed it was leaking quite a bit while driving. My guess would be either hosing or a water pump but I'm not really sure where I should start. I also have a ses light and while trying to scan it I keep getting errors then eventually I got a few codes that I believe are all 4 o2 sensors. Is there a fuse that might be blown that would cause this? I also can't reset the light, is that normal? It might just be my obdii tester i've had for ages but figured I should throw that in while I'm at it.
Old 04-08-2019, 03:33 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Fuse? No. You have a 17 year old car with multiple problems, mechanical and electrical. There is nothing more expensive than a cheap BMW. Take it to a reliable specialty shop and pay your share.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 04-08-2019, 05:47 AM
1bad540's Avatar
1bad540 1bad540 is offline
def sounds like you have more than 1 issue. was car on a battery tender? Low battery will cause some prblms. looks w a flashlight to see where the leak is.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 04-08-2019, 02:55 PM
It's not about not being able to afford to fix it. If I was worried about money I wouldn't have bought the m3 in the first place. I just thought it was odd that all 4 o2 sensors would go at the same time and figured I should start small and go from there.
Old 04-08-2019, 05:47 PM
targaone targaone is offline
Mein Auto:
I would find a local indy shop. Have them start by fixing up your cooling system then whatever basic maintainance you need. Brakes , cooling , belts , suspension, tires , electrical. Along the way they will do a scan code check... this stuff is not unusual for an older car , especially a bmw.
Make sure the basic bones of the car are good enough to justify all the repairs before you start writing checks... corrosion, prior accidents, massive computer issues are something to look at before the first 800 or 1200 dollar installment.
Similar Threads
Proximity Warning when Parking FluTricolor X3 G01 (2018 - current) 11 03-07-2019 08:22 AM
Mystery Coolant Problem goldylox E85 / E86 Z4 (2003-2008) 13 10-29-2018 05:36 AM
08 528i Code Questions 2E98, 2E85, 2E81 blue02gt E60 / E61 (2004 - 2010) 17 04-15-2018 09:37 AM
DIY changing coolant kurti 5 Series DIY 7 10-13-2007 08:31 PM
Bleeding Coolant 2001E46 Do-It-Yourself H.Q. 2 08-04-2003 10:46 AM
