318i with the N43 Engine is burning oil - Bimmerfest - BMW Forums
Old 04-14-2019, 12:53 PM
joy310 joy310 is offline
Mein Auto: 318i E90
Hello everyone!
I have a low mileage E90 (80.000kms) which started to need a lot of oil about 1 year ago. It uses about 1L/1500 km.
I am assuming it's burning it, as yesterday I got an 29F4 CO Catalytic converter error and I bet it's because the oil goes in the exhaust.
Is there anybody who owns a car with this engine and had the same problem?
The mechanic said the valve stem seals need replacing, but he didn't do any tests and I am a bit afraid to agree to such a complicated job without being sure they are indeed faulty.
Any advice is greatly appreciated.
Thank you!
Old 04-16-2019, 10:36 PM
satyaban satyaban is offline
Mein Auto: 2008 328xi
Is the car throwing up any codes, I am pretty sure if you are burning oil it should present itself. If you have emissions testing in ROM you should fail that if you are burning oil but that is a double edged sword in that if you fail it may generate some kind of repair order or something.
Old 04-16-2019, 10:41 PM
Mein Auto: 318i E90
Hello and thank you for your reply! The only code it's showing is the 29F4- CO Catalytic converter below threshold so I'm assuming it's indeed burning it. But I have no idea what may be at fault. I am blaming the valve stem seals or piston rings, but I haven't found a mechanic that can test them and come with a decent answer.
Similar Threads
E70 X5 Engine Oil Cooler Bolt, torque spec, re-fitting 2011x5 X5 E70 (2007 - 2013) 4 01-07-2019 11:44 PM
328i Oil Consumption ashk86 F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 18 12-16-2018 11:33 AM
My Engine is burning oil SupraHom E39 (1997 - 2003) 19 06-15-2007 03:24 PM
2001 325i Burning Oil Smell from engine Qs325i 3 Series & 4 Series 10 04-15-2004 07:37 AM
BMW Update for S54 Engines BMWNA 1M & M2 2 08-13-2003 05:55 PM
