e90 328i small engine leak ? - Bimmerfest - BMW Forums
Old 04-14-2019, 01:42 PM
aikikai aikikai is offline
Mein Auto: BMW
Hello,
I took my engine cover off to inspect for leaks.. I found this, between 4th and 5th coil. Does anybody knows what this is exactly ??? What is cause of this ? Is it problem in bolt ?
My lady ( bmw ) has only 65.000 miles
Thank you
ID:	847927   Click image for larger version
ID:	847929   Click image for larger version
ID:	847931   Click image for larger version
ID:	847933   Click image for larger version
ID:	847937   Click image for larger version
ID:	847939   Click image for larger version
Old 04-14-2019, 08:55 PM
relative4 relative4 is offline
Mein Auto: '08 335xi E90 manual
Either the valve cover gasket or just a spill from an oil change.
Old 04-15-2019, 03:44 PM
Mein Auto: BMW
it might be valve cover gasket cause i saw some plastic pieces... it should't be hard to replace it...
Thank you.
Old 04-18-2019, 12:36 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
Clean it with brake spray or equivalent, then watch it for awhile.
No return means spilled oil from oil change.
If it comes back, possible the appropriate inner gasket piece that the stud goes through has a leak.
Not in any way serious.
here's the gasket set. https://www.fcpeuro.com/products/bmw...-11127582245kt
possibly one of those three gaskets in the center of the picture.
In another matter, unplug the connector to the eccentric shaft sensor (top front of engine) and see if there's oil visible in the electrical connector. If so, and you decide you need to do the VCG set, consider the ESS as well at the same time.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 12+ Years
Old 04-18-2019, 02:53 PM
Mein Auto: BMW
Thank you so much for taking time to write down all of this, i appreciate it !
When i get free time again, i'll do as it is written.
Thanks !
Similar Threads
2015 228i CPO engine leak and gasket replacement Zee010 F22 / F23 2 Series (2014 - Current) 21 05-10-2018 10:41 PM
328i small oil leak... Nfelton E36 (1991 - 1999) 4 03-20-2018 06:38 AM
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
Infiniti G35 a reliabilty nightmare. Kayani_1 E90/E91/E92/E93 (2006 - 2013) 107 11-17-2007 11:33 AM
BMW Update for S54 Engines BMWNA 1M & M2 2 08-13-2003 05:55 PM
