Roadster Top Release Adjust - Bimmerfest - BMW Forums
Old 04-14-2019, 02:19 PM
Stinger22 Stinger22 is offline
Mein Auto:
New motor and new module when I bought a couple of months ago.
About 3 out 5 times when I start the opening sequence the latches unlock and motor starts but I have to put the slightest bit of pressure right under the inside of the driver corner to get the hinge "unstuck" then it operates normally. The motor will just whine until I do but just the slightest little encouragement.
Any tips on how and where to adjust this?
Old 04-14-2019, 08:29 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Hinges might just need some light lubrication. There are a few threads on this topic, heres one:
https://z4-forum.com/forum/viewtopic.php?t=27567
[SIGPIC]
Old 04-15-2019, 05:50 AM
Mein Auto:
Naw checked that clean and is greased.
Old 04-15-2019, 07:23 AM
elerner61 elerner61 is offline
Mein Auto: '07 Z4M Roadster
Check the roller on the header part of the latching mechanism. One of mine was binding years ago. I unbolted the entire unit from the header (easy to do). Popped the small axle on the roller, addressed the binding and all was good afterwards. 30 mins tops.
Old 04-15-2019, 08:55 AM
Rob2m Rob2m is offline
Mein Auto: Z4
There is a white plastic adjuster on the bowden cable that is attached to the red ring in the boot, if it is slightly too tight it can reduce the pumping pressure of the hydraulic fluid.
Its located on the u channel in the boot up in the left hand side, follow the cable from the pull ring.
"Today’s ride will remind me forever how good it is to be a motorcyclist, how good it is to be alive and how much we need to live life, rather than watch it pass us by." Green VFR.
Old 04-15-2019, 05:44 PM
Mein Auto:
Thanks will try those two this weekend!
Similar Threads
June 8,2008 Riverside Ca Race Muzeum imz4n E36/7 Z3 (1996-2002) 30 08-29-2009 09:39 AM
Latest Software CIP 19.02 chuck92103 E63 / E64 6 Series (2004 - 2010) 30 11-13-2005 12:38 PM
M Roadster Is Back For 2006 tim330i BMW News 0 11-08-2005 10:04 AM
FS: M Roadster center console panels bimmerZ5 Interior 0 10-09-2005 09:00 PM
Prices for New 2003 Z4 Roadster ChrisTO E36/7 Z3 (1996-2002) 0 09-19-2002 07:04 PM
