d/s front window - Bimmerfest - BMW Forums
Old 04-15-2019, 08:39 AM
e90328nl e90328nl is offline
Mein Auto:
d/s front window
having a little issue with the driver front window. if i use the auto up to close it the window will go all the way up and instead of stopping in the closed position the window will go back down to about 1/3 open. i can inch the window closed by bumping the switch until it is fully closed and it will not open on its own that way. auto down works normally and the operation of the other 3 windows is normal. i did have the battery unhooked yesterday for a few hours for another repair under the hood, the window worked fine previously to that, only started doing this today. any thoughts?....thanks!!
Old 04-15-2019, 02:55 PM
gbalthrop gbalthrop is online now
Mein Auto: 2007 328xi E91
Sometimes certain components such as windows, sunroof, steering angle sensor, compass in rear view mirror, may need to be "reinitialized" after battery was disconnected. You can use INPA, F6, F1 Window Initialization if you have INPA. Here is the TIS procedure for front window initialization done without any software or cable:
https://www.newtis.info/tisv2/a/en/e...ulator/HmL0y0i
Please let us know if that works for you,
George
Similar Threads
tips for front passenger window replacement?! kekillion E39 (1997 - 2003) 3 08-25-2018 12:51 AM
Fuse Front window issue 2012 X5 lofster X5 E70 (2007 - 2013) 2 05-28-2018 09:31 PM
The New 5th Generation BMW 7 Series Breaks Cover tim330i BMW News 18 08-12-2008 04:17 AM
Front window track broke! ronpapworth E36 (1991 - 1999) 1 06-19-2007 11:52 AM
