Remove the headlight lens - Bimmerfest - BMW Forums
Old 04-25-2019, 11:40 PM
mkhounani mkhounani is offline
Mein Auto: 2005 BMW Z4
My headlight lens looks terrible. After our rainy season, I took my headlight out for check up and found at least a quart of water plus a whole bunch of sand, yes sand, lots of it in there. I also need to rewire the entire headlight. Does anybody have any information on how to remove the lens cover from my headlight so I can clean the big film of dirt from it or how to rewire my headlight without losing track of it? I would be very grateful to whoever can help me with this.
Thanks.
Old 04-26-2019, 09:48 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
As far as I know, the lens is bonded to the housing and I don't see a way to remove it without damaging both. Also, I believe the only openings to the assembly are where the bulbs insert, so not sure how all that water and sand got in there. Perhaps someone else can weigh in on this.
[SIGPIC]
Old 04-27-2019, 08:50 AM
Clearancediver's Avatar
Clearancediver Clearancediver is online now
Mein Auto: 2004 Z4, 2009 Nomad mc
From the posts Iíve read on this issue.... the leakage/moisture issue is a result of the failure of the seal where the light bulb is inserted. When the seal has been replaced, posters report the issue going away.
It makes eminent sense for the seal to be the cause....
Cleaning the interior of the assembly.... you said you had removed the assembly.... use a solution of water and a soil remover and pour in.... shake away. Do this a couple of times until it seems clean. Change the solution to Windex window cleaner...shake as above.
Use clean water to rinse a couple of times, then position it to drain/dry. Finish off with a hairdryer blowing into assembly.
Install new seal.
Wiring... take a photo of wiring close up. Use tape to label wires downstream/upstream of where you cut to replace wires...
headlight, lens, removal, rewire
Similar Threads
N62/E65/E66 Valve Stem Seals Replacement, Valve Cover and Timing Chain Case Gasket Knight's Master Tech 7 Series DIY 21 04-23-2018 08:32 PM
Headlight Assembly Replacement team321 E39 (1997 - 2003) 59 12-20-2015 01:05 PM
AAA is towing my car in 30 minutes (total electrical failure) bluebee E39 (1997 - 2003) 220 07-06-2015 12:15 PM
Does anybody know how to remove the air intake box? zabrak999 E39 (1997 - 2003) 14 01-12-2015 03:55 PM
I found the correct Headlight Cover Lens Part # for my 03 330i - I think (99.9% Sure) LKNGOOD E46 (1999 - 2006) 18 05-30-2009 01:57 PM
