Yet another top issue - Bimmerfest - BMW Forums
Old 05-03-2019, 11:37 AM
p598738 p598738 is offline
Mein Auto: Z4 2,5 and 3.0
Top suddenly not working. New motor and hinges recently installed. Drains are clean.
One possibility is the 'micro switch' used by the trunk shelf. I understand that the micro stops the motor from working if the shelf is up. I am looking at it and not sure what position it is in.
Please see the picture and tell me what the situation is (if you know). What position should the switch be such that the motor top will work ???
Name:	Micro switch.jpg
Old 05-03-2019, 08:51 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Since the trunk shelf was removed and reinstalled when you replaced the top motor, the microswitch may have been disturbed. They are pretty fragile. You can repair, replace or even bypasss the switch if necessary. This may help: https://www.bmwrepairguide.com/bmw-e...switch-repair/
[SIGPIC]
Old 05-04-2019, 11:59 AM
Clearancediver's Avatar
Clearancediver Clearancediver is online now
Mein Auto: 2004 Z4, 2009 Nomad mc
Your microswitch lever is missing.... it probably fell off.
Replacing the microswitch is a easy DIY.
Old 05-04-2019, 12:54 PM
Now I'm not so sure it could be the microswitch. The down button blinks or is solid red.
Old 05-04-2019, 01:29 PM
The lever is missing in the picture.... hence an error condition is set. The car thinks the storage tray is in the “up” position.
Old 05-06-2019, 09:35 AM
Hmm, yes I think it blinks yellow when the tray is up. Red could be another issue.
[SIGPIC]
Old 05-09-2019, 03:35 AM
Replacing the switch today. Fingers crossed.
Old 05-09-2019, 04:44 PM
No luck. It was not the micro switch. Diagnostics suggest the top motor is shot.
The latest one was installed in December 2017. The car was garaged from May 2018 until October 2018. It's been on the road less than 12 months in total since the new one (#3) was installed.
The newest motor may have been defective. Stay tuned.
top micro switch
Similar Threads
New User - iDrive/Spotify/iPhone Issue JGButler F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 7 11-15-2016 02:47 PM
BMW 328d torque jumping at idle, causing car to shake violently mattp1 F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 10 05-20-2016 04:49 PM
How I solved 2A82-2A87 issue Endive E63 / E64 6 Series (2004 - 2010) 0 05-13-2016 12:27 PM
Gas Mileage Issue on 2008 328i Sedan piyu7444 E90/E91/E92/E93 (2006 - 2013) 11 10-08-2012 08:29 AM
