Top problem - Bimmerfest - BMW Forums
Old 05-05-2019, 08:25 AM
Bob Stech Bob Stech is offline
Mein Auto: BMW Z4 2006
Top problem
My top fully retracts, but motor doesn't cycle off, dash light blinks red. Trunk knobs fully retracted. Help
Old 05-05-2019, 06:34 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
There are two sensors mounted on the left side hydraulic lift cylinder. One senses the top up and the other top down.
Either there's something jamming the top and it's not really fully down, or the other possibility is the sensor has failed.
What year is your E85?
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 05-05-2019, 09:12 PM
Andyz4 Andyz4 is online now
Mein Auto: 2006 Z4 3.0si
Will the top go back up with the switch?
[SIGPIC]
Old 05-06-2019, 06:39 AM
Thanks I'll have a look at the sensors. Top works fine going up. Motor sounds fine. My car is a 2006 3.0 Si
Old 05-07-2019, 07:42 PM
dc_wright's Avatar
On the inside of the top frame, just above the lift cylinders there's a plastic shield on each side of the car. Their purpose is to keep the top/head liner from getting pinched in the top frame when it folds. These have been known to break loose due to age, and either the plastic piece gets caught in the top frame or the head liner does. In either case the top won't fold down to the final correct resting place and you'll have the flashing incomplete cycle LED. Put the top about half way down to remove the tension on the head liner and look behind it to see if the plastic pieces are in place.
https://z4-forum.com/forum/viewtopic.php?t=50000
Old 05-09-2019, 08:34 AM
DC_Wright Thanks for your help. My top doesn't have the plastic side pieces, in fact there are no mounting points for them. Maybe my car was manufactured before these were added? Mfg date 03/06. In all events nothing seems caught in the headliner or top and it seems to fully retract. I live in western Colorado and nearest dealer/shop is 250 miles away. Guess I'll live with it until I make it over to Denver. Thanks again for your input.
Old 05-24-2019, 05:23 AM
Migizi Migizi is offline
Mein Auto: X3
I have the same exact issue (after removing top and replacing headliner).
Anyone have a picture of these sensors?
Old 05-24-2019, 06:12 AM
Photo of Sensors
If you look at DC Wright's response he posted a link to a Photo of the sensors. you can see them easily with the top and headliner still in place. BMW service apparently has diagnostic equipment to determine if a sensor is bad. That's my next stop.
Old 05-24-2019, 06:20 AM
Mein Auto: X3
I found my problem, when I reinstalled the top, it looks like I broke one of the sensors
Old 05-24-2019, 09:25 AM
Mein Auto: X3
can the Hall effect sensor(s) be ordered separately from the left hing assembly?
does anyone know the part number?
Old 05-24-2019, 05:36 PM
dc_wright's Avatar
Should be item 36.
http://bmwfans.info/parts-catalog/E8...p/folding_top/
Old 05-25-2019, 02:56 AM
Mein Auto: X3
awesome - thanks!
Old 07-15-2019, 07:12 AM
Top Prob Cont
Still haven't solved my top problem. BMW service was no help. Charged me $150 to run a scope down and look at the motor. Motor ain't the problem. Does anyone know how to check the Hall sensors to determine if they are working?
