Valve cover and oil filter housing gasket replacement - Bimmerfest - BMW Forums
Old 05-08-2019, 10:58 AM
francophile francophile is offline
Mein Auto: 2006 Z4
My 2006 3.0 had some small but ongoing leaks around the valve cover and the oil filter housing. I decided to undertake the project as a whole. I ordered two kits from FCP/Euro for the project. The kits had more than the just the gaskets.
Having spent a whole day doing these two projects, which included the eccentric shaft gasket, the VANOS gaskets and the oil filter housing gaskets and the accompanying bits, I am thrilled with the results.Its runs just a little smoother and I don't have to worry about oil in the alternator or any of the belts.
Its not fun to do it but it is worth it. Im at 118,000 now and hope to see a few more miles.
Next job: water pump, radiator and tank.
Old 05-10-2019, 06:26 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Nice Job! Good idea to do the cooling system as preventative maintenance. The only issue you may run into is the lubricant they use at the factory for the snap on hose fittings turns into the equivalent of structural epoxy with age and heat and they can be a real bear to get off.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 05-12-2019, 07:40 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Funny I just did both mine last weekend at 118k also. Unfortunately mine was necessitated by the loss of my alternator from the ofh leak, so you were wise to get yours done.
[SIGPIC]
Similar Threads
Oil Filter Housing & Heat Exchanger Gaskets DIY dukedkt442 X3 E83 (2004 - 2010) 53 11-12-2018 07:26 PM
How NOT to replace a VCG (What can go wrong when replacing an E39 valve cover gasket) bluebee E39 (1997 - 2003) 50 12-11-2017 12:20 PM
E63/64 DIY: BMW 650i / 645Ci Oil Change and Check Control Reset Yorgi 6 Series DIY 119 04-16-2017 05:50 PM
DIY E39 - Oil Filter Housing Gasket R&R ('02 525i - M54) BbradenMmillerW 5 Series DIY 1 06-22-2016 09:46 AM
N52 bolts for oil cooler, oil filter housing, and valve cover gaskets? Chris F. X3 E83 (2004 - 2010) 6 03-02-2015 04:17 PM
