Brake cooling intake - Bimmerfest - BMW Forums
Old 05-13-2019, 02:29 AM
Rotorblade Rotorblade is offline
Mein Auto: Bmw x1
I would like to show you a pair of carbon fibre intakes I intend to connect to neoprene air ducts. The CF - aluminum combination looks nice I think. They finish is not too good because I had some problems with the moulds and the vacuum as well and had to do a lot of sanding.
The shape was chosen so that they fit into the space I had and also to make the mould easier to cover with the CF sheets, although it's not very effective in collecting air. The air ducts are 52mm in diameter, hopefully they will make a difference on the track.
Old Yesterday, 04:50 AM
Mein Auto: Bmw x1
I've managed to fit the air duct to the left wheel using 2mm aluminum sheet. The brackets may need reinforcement like for example a 90degree triangle to make it hold against vibrations although it sits firmly as it is.
The heatshield adaptor lets the air into the center of the disc unrestricted. It's basically a bent pipe so that the section area remains the same, only the shape changes gradually.
The hose clamp is aluminium so it case something goes wrong the aluminum sheet doesn't damage, but it is also riveted to the adaptor.
ID:	852553   Click image for larger version
ID:	852555   Click image for larger version
Old Yesterday, 07:51 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
That is an impressive bit of fabrication. Do you track your car?
[SIGPIC]
Old Today, 03:25 AM
Mein Auto: Bmw x1
Thanks. I usually go a few times a year to a racetrack and do 1 or two sessions of 20minutes. The brakes get hot quite fast I can do 1 or 2 laps with moderate braking before a cooling lap is needed. Last year I've installed a set of EBC yellow pads with ebc discs and pushed them too much (after breaking them in) because I thought they will handle heat better and the fluid boiled. I didn't know when to stop. When they are hot they start vibrating slightly and that should be the signal for a cooling lap. Hopefully with this vent system the brakes will last a bit longer and wear slower.
Similar Threads
DIY: 1998 BMW 528i, PARKING Brake Overhaul cn90 E39 (1997 - 2003) 41 05-11-2019 03:33 PM
the VERY best of E39 Links chivas E39 (1997 - 2003) 107 12-29-2018 05:09 AM
Complete BMW OBD II codes doru E39 (1997 - 2003) 5 10-19-2017 03:44 PM
Rotor Refinishing does that stuff work? stigst3r E39 (1997 - 2003) 80 07-22-2015 11:41 PM
In a case of brake system fails t_clealy 7 Series - E65 / E66 (2002 - 2008) 32 09-20-2010 06:07 AM
