Sticky Steering - Bimmerfest - BMW Forums
Old 05-14-2019, 12:53 PM
bimmerfastest bimmerfastest is offline
Mein Auto: 328i
Sticky Steering
I have a 2010 328i.
When coming out of a parking spot in reverse and turning the steering wheel all the way to the right it becomes hard to turn it back to the left. It requires a great deal of effort to start turning to the left until there is a noise coming from the front-right side of the car and the steering become unstuck.
After that the steering works normally.
Any idea of the source of the problem?
Old 05-15-2019, 08:42 AM
relative4 relative4 is offline
Mein Auto: '08 335xi E90 manual
I don't have any suggestions, but if you get it worked out, please post the resolution. I'm developing a similar problem and will follow this thread. I will likewise post if I fix it.
Old 05-15-2019, 11:10 AM
gbalthrop gbalthrop is offline
Mein Auto: 2007 328xi E91
Originally Posted by bimmerfastest View Post
...2010 328i When coming out of a parking spot in reverse and turning the steering wheel all the way to the right it becomes hard to turn it back to the left. It requires a great deal of effort to start turning to the left until there is a noise coming from the front-right side of the car and the steering become unstuck. After that the steering works normally.
If there is a "pop" or "click" from the right side when the "stuck" part releases, you should be able to hear/ feel the source of the sound if you have a helper turn the wheel while you listen or feel various parts for the sound or feel of the "release."
I can't think of any reason why forward or rearward movement would be required, as opposed to just turning to "full-lock-RIGHT" and then trying to turn wheel back in counterclockwise direction. First suspect would be a rusted ball joint in steering knuckle, or possibly an issue with the RF Strut mounts?
If you ONLY have the sticking during, or just after moving rearward, THAT would be significant.
George
Similar Threads
The All-New 2017 BMW 5 Series: The Premium Sports Sedan Redefined tim330i G30 (2017 - Current) 109 07-09-2017 02:18 AM
Is all BMW steering numb? VanillaCracker F22 / F23 2 Series (2014 - Current) 32 02-16-2017 10:41 PM
Sticky Steering burlovgolf E85 / E86 Z4 (2003-2008) 12 10-05-2016 02:52 PM
Does anybody know how to remove the air intake box? zabrak999 E39 (1997 - 2003) 14 01-12-2015 04:55 PM
Need help with tire/handling problem pmcwhinnie E39 (1997 - 2003) 5 12-22-2006 01:46 PM
