Warped rotors? - Bimmerfest - BMW Forums
Old 05-15-2019, 05:39 AM
535kjp 535kjp is offline
Mein Auto: 2011 535i XDrive
Warped rotors?
Hey all,
I have a 2018 330i with 6.5k miles on it. Began to realize that you hear the brakes rumbling between 65-80mph. It hasn't gotten to the extent that it shakes the entire car yet, so if the music is loud enough, it's not particularly noticeable.
Are warped rotors covered under warranty this early? I know BMW removed brakes/rotors from maintenance, but this doesn't seem like regular wear and tear to me. I generally don't do too much spirited driving, and don't slam on my brakes so I'm a bit confused
Old 05-15-2019, 07:17 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
It is unlikely that YOU can warp a 25 mm rotor. More likely you have deposited pad material stuck and making high spots.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 05-15-2019, 07:56 AM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
What Doug said. You need to do a few "panic stops" to remove any pad deposits that have accumulated.
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 05-15-2019, 09:17 AM
pshovest pshovest is online now
BMW CCA 69606
Mein Auto: '15 435i '10 535i '08 X5
Very unusual for factory pads to leave deposits, they are incredibly abrasive and scrub the rotors well. If you can feel the shake, you've got a braking performance issue. Car should be under factory warranty. Complain to dealer when several aggressive stops from 70 - 0 MPH don't fix it.
Old 05-15-2019, 09:25 AM
Nuclear engineer
Aggressive stops from 70 MPH to 5 MPH. Do not leave the pads resting on a stinking hot disc.
Old 05-15-2019, 10:34 AM
BMW CCA 69606
Absolutely correct.
Old 05-16-2019, 09:21 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
The rotors may also have developed a glaze which gives a shuddering sensation. Doug's remedy should work.
Old 05-17-2019, 04:40 PM
I tried the 70-5 a few times. Still feels a little uneven but its pretty bearable now
Old 05-17-2019, 05:27 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: 944 Turbo M235 Z4 335Mcar
I've had this a few years back, I took the rotors and cut them. Problem solved.
Similar Threads
Brake rotors warped / Pad ? PaulPt E90/E91/E92/E93 (2006 - 2013) 10 05-27-2016 10:16 AM
3rd Set Of Warped Rotors..Help Diamond_Ed E63 / E64 6 Series (2004 - 2010) 15 03-25-2013 12:02 AM
Warped Rotors shendrick X3 E83 (2004 - 2010) 7 12-21-2011 09:13 AM
All four rotors warped after a few thousand miles JejuneLegume E82 / E87 / E88 / F20 1 Series (2008 - 2014) 2 09-10-2011 02:25 PM
Control Arm Bushing vs Warped Rotors casino hairpin E34 (1989 - 1995) 4 05-23-2008 02:57 PM
