Bavsound review - Bimmerfest - BMW Forums
Old 05-15-2019, 12:49 PM
Yukoner Yukoner is offline
bimmerfest Supporting Member
Mein Auto: 2011 328i x-drive
Bavsound review
OK, so about a half year ago I noticed that the tweeter in my front passenger door on my 328i was having problems. Certain frequencies would cause major distortion. The mid-range driver also had issues here and there, so I presumed it was on its way out as well. Through plenty of research (*cough* ctuna *cough*), I learned lots about the BMW factory audio system. In other words, I basically learned that there's no way in hell I want to f*** with it No, seriously, IMO it's too integrated into the vehicle on a whole. Unless you're willing to pay big $$$ for a competent audio shop to do it, or you have a lot of experience yourself with these specific vehicles, I personally wouldn't touch it.
FWIW, I'm not someone who knows nothing about aftermarket audio. I have spent many hours and many dollars on aftermarket sound systems for vehicles, from Rockford Fosgate (back when they were cool ! ) to Cerwin Vega. I was even one of those idiots that bought an in-dash motorized LCD display from Alpine back when they were $3K.... And now you can buy on Amazon for $249..... Anyways, my point is, I've done lots of car audio in my driving years, and I'm not afraid to take things apart, run wiring, etc.
I was about to pull the trigger on ordering stock OEM replacements, when I came across Bavsound. Plug and play, no modifications needed, drop-in replacement. Hmmmmmmmmmmm I checked out some reviews and what others have said on forums and everyone seems to be pretty happy with them, so I figured I'd give them a shot. I ordered up a Stage One speaker replacement kit (this replaces all the door and rear shelf speakers in my HiFi system). One thing about Bavsound that sucks is that they don't ship outside the USA. So I wound up shipping it to my address in Alaska, and making the 5 hour round trip to go pick up the package when it arrived.
I had the speakers installed by my indy as I had some other routine maintenance to do on the car anyways.
I'll start by saying that I wasn't "blown away". But I'll also start by saying that isn't the fault of the speakers. Let me explain. There are two measurements that most people will use when evaluating how an audio system sounds. One is quality, and one is quantity.
On the quality side, Bavsound isn't even in the same category as OE. The quality of the audio Bavsound can produce is absurdly awesome. Everything from clarity to tones you couldn't possibly hear or distinguish with the OE setup. These speakers are well made and it certainly shows in their performance (see the magnet difference from OE to Bavsound in the attached images). I could write a super detailed essay about the differences between OE and Bavsound, but no one would probably read it, so suffice it to say, these are ABSOLUTELY worth the upgrade.
On the quantity side, this is where I was disappointed. "Quantity", from an audio perspective, can also be understood as loudness, or volume. IMO, these speakers are actually not as loud as OE. Cranking the volume knob to max actually results in a quieter overall volume than OE. Ummmmmmm, what the hell ? Back to doing more research, this is actually a common perception from Bavsound'ers. I suspected (and confirmed from research) that the issue is now the factory amplifier. The factory amp only has 205 watts vs Bavsound's 645 watts.
Now, quantity, or loudness / volume matters a lot to me. My hearing isn't the best as it is, so to really enjoy music, I tend to have to louder than most folks probably would.
All in all, I am very happy with the Bavsound speakers. They are, without a doubt, a major upgrade from the OE speakers, and I would recommend them to anyone. For me, it looks like I'll need to also swap out my amp, so when I do that I'll update this thread with my further thoughts
ID:	851981   Click image for larger version
Not even sure if -40 degrees is cold anymore ?
Old 05-15-2019, 01:59 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Since you said amplifier and 200 watts I will assume you have the Hi Fi
(Do you know what the impedance of the Bavsounds are because the
stock Hi Fi is 2 ohms. 4 ohm speakers will mean you get about 1/2 the power.)
system. The standard fix for that system used to be and aftermarket amp
and then speakers.
And aftermarket amp is easy to add with the Technic Hi Fi Harness.
The standard one we used to use is the JL xd600/6.
The amp connector is a one throw switch.
If I was doing this now I would get one of the Helix amp/dsp's
Both Bimmertech and Bavsound are putting there name on these and reselling them.
Bimmertech uses the Helix 86 dsp/amp now
and Bavsound uses the Helix BMW 7.
The advantage of buying these from them is they come with a tune .
If you do not want to play with wiring and tuning this may be the easiest
way to go.
Old 05-15-2019, 03:44 PM
and then speakers.
way to go.
Bavsound is 2ohm impedance. I thought about going aftermarket with the amp, but exactly as you said, I'd have to play with wiring (didn't know about the pre-tuned). Normally I'd be totally fine with wiring, I've done it dozens of times, but something about plug and play with the BMWs that I like. Keeps a more stock-ish nature of the vehicle.
I'll check out the cost difference, but cost isn't the deciding factor for me (in this case, anyways), so I may just go with the Bavsound amp.
Thanks for the info tho, you continue to educate me on BMW audio
Old 05-15-2019, 03:54 PM
rdkind62's Avatar
rdkind62 rdkind62 is offline
Mein Auto: 2011 BMW 335is, 2007 X3
As a retired artilleryman with tinnitus and about a 50% hearing loss (being fitted for a hearing aid next month) I'm not sure I have any reason to try and improve my sound system, but appreciate the write-up. One of those that can be linked to in the future for those that want to work the same issue.
BMW 335is, Cobb tune with VRSF intercooler, Injen CAI, and BMS downpipes. 382/414 rwhp/tq. Le Mans blue with Black Dakota leather, Convenience and Premium packages, 19" wheels, 7 speed DCT, heated seats, Nav., Harmon Kardon Logic 7 stereo w/ Satellite radio.
Old 05-15-2019, 04:02 PM
Sorry to hear. I thankfully don't have tinnitus, but I don't have the hearing sensitivity that the average person does (I don't think I "lost" it, which is why I don't call it hearing "loss"), hence the need to turn volume up louder than most probably would on a normal day.
Old 05-15-2019, 06:13 PM
With the kind of harness they have(bimmertech/bacsound) its as simple as throwing a lever
and plugging in the connector then throwing the lever in the other direction.
If you do this yourself with a Technic Wire harness it still is no more difficult than
setting up a Home Entertainment system with the exception of running some
real DC power wires to the Battery with a fuse.
I believe both the kits from Bavsound and Bimmertech bypass this step to make
it more plug and play .
Also if you deciede to do this tell them which speakers you have as they have DSP tunes
for stock and aftermarket speakers.
The tune is for the DSP it's something you can do for yourself if you like doing
that sort of thing.
Check the Helix/Match audio tech site
https://www.audiotec-fischer.de/en/m...fiers/pp-86dsp
https://www.audiotec-fischer.de/en/m...ifiers/up-7bmw
Old 05-16-2019, 07:24 AM
Black Valkyrie Black Valkyrie is offline
Mein Auto:
For those not wanting to spend $$...
I determined that 5 of my speakers had the distortion issue. After removing one and studying it, it became apparent that the reason there is distortion is that the glue which bonds the 'spider" to the coil was brittle and had separated on each and every speaker with an issue. Simple and judicious use of a hot glue gun solved this. Takes some effort but it is more or less a free fix.
Old 05-16-2019, 10:38 AM
that sort of thing.
Hrmmmmmmmmmm.
Old 05-16-2019, 11:38 AM
CamCrazy's Avatar
CamCrazy CamCrazy is offline
Mein Auto: AUDI A4 3.0 B6
For all the money they charge it should be a lifetime warranty
Old 05-16-2019, 01:37 PM
I figured this kind of comment would eventually come up. They are not the cheapest speakers on the planet, no, not at all. That being said, as a direct OE replacement that requires zero splicing, zero drilling, zero anything, they are unmatched.
While cost certainly matters and is always a factor, the difference from $250.00 to $450.00 (to me) is negligible, and I personally feel a vehicle that originally cost $60K is worth the investment. In my opinion, the quality, OE replacement-ness and excellent backend vendor support are well worth the extra dollars. That being said, I do realize that everyone will have their own opinion on this, so I'll leave it at that. There ARE cheaper ways to do this, and to each their own.
Old 05-16-2019, 02:14 PM
CamCrazy's Avatar
Agreed @ Yukoner . But quality and endurance should be expected. Not just at the point of purchasing but years to come . Nothing last forever I know .
Old 05-16-2019, 03:09 PM
actually there are quite a few company't puttng out plug and play speaker
kits for the e9x now. Jehnert , Audiotec Fisher Match , Mb quart, Rockford Fosgate
, Audio Systems, Gladen, Rainbow some other Euro brands I can't remember.
The sound system's that BMW puts in there cars now are pretty pathetic fior
a 50k plus out the door.
https://www.e90post.com/forums/showthread.php?t=343673
Old 05-20-2019, 08:41 PM
Completely agreed. I don't understand this at all - everything else is so well done and then this piece is completely neglected
Old 05-20-2019, 08:45 PM
It's not like there alone most car companys's don't put 0ut a good
stereo even the B& 0's and Bose are not that good. But the e46 Hk
system never made me wish I had that much more.
I don't like this trend of using a lot of small speakers and surround sound.
Hard to get much depth and presence from a 4 inch speaker.
Or sub 4 inch
Old 05-21-2019, 10:10 AM
I had Bose in my Mazda RX8, and honestly it was a pretty good system. I wished it was a tad louder (in volume), but otherwise, it was great. Agreed though, the 10+ speakers these days are overkill.
Old 05-25-2019, 04:24 PM
UPDATE - The system's been running, probably, 5 to 6 hours at this point. I've read this elsewhere but it's absolutely true: these speakers NEED to be warmed up / broken in. The sound was already amazing to begin with right when they were installed, but I have to say, they're almost twice as good now. I'm not a sciencey-audiophile, so maybe I'm using the wrong terminology here, but the clarity and sharpness got a lot better (maybe still getting better ? I don't know how long they take to really break in). I'm still unhappy with the max volume, but as I noted, going to need to swap the amplifier to get that fixed as it doesn't appear to have anything to do with the speakers themselves.
Old 05-25-2019, 04:31 PM
Mein Auto:
Surprised no one else has commented on simply repairing the speakers like I did. It is basically a free fix other than your time and restores the sound back to as it should be.
Old 05-27-2019, 10:37 AM
Yes but this isn't just about replacing a broken speaker. It's also about improving sound quality and making the overall audio experience "better"
Old 06-03-2019, 07:29 PM
11e90Ride 11e90Ride is offline
Mein Auto: '11 328i
Yukoner, faced with what i thought was a sub-par audio experience, I ALMOST did exactly what you did, until I realized the impedance of the BAVSound speaker replacement, and what I might like to end up doing. I had acutally ordered the BAVSound speakers and decided to cancel the order.
I instead replaced the Hifi amplifier with a JLAudio xd600/6 inititally. What a difference that made. For the money, it seems to the best first step in cars with HiFi. It's simple to do if you can source the right PnP harness, and provides a substantial improvement.
Eventually, however, I replaced the separates in the front doors with Morel Virtus separates, and replaced the underseat woofers with 4 ohm earthquakes SWS8s. I disconnected the rear deck, drove the fronts with the first two channels of the XD and bridged the rest of it to drive the underseat woofers. Pretty clean and powerful.
When the combox failed last year, I replaced the radio with a Pioneer AVH NEX unit that gave me the ability to adjust the sound curve, levels, and timing a bit more, so its sounds even better. Plus it has Android Auto, and better integration with my phone's bluetooth.
I really wouldn't change anything or the order of execution, except I might have replaced the head unit sooner had I known what i was missing. In my book, that 'HiFi' Amp is the weak link in the factory audio system without question. It is under-powered and not well-suited to drive 4-ohm loads, limiting your speaker options.
We had two E90s for a while...I put XD600/6s in both of them.
That's my $0.02.
Old 06-03-2019, 08:09 PM
I will add my .02 cents to your .02 cents and say that is exactly correct.
Old 06-04-2019, 09:05 AM
That's my $0.02.
Yep, absolutely agree with you that the amp is a serious limitation. Had I known this, I'd have ordered the amp at the same time as the speakers. Lesson learned, lol
Interesting you replaced the head unit. My understanding is that removing the factory head unit causes problems down the road ? Was it the DME that has problems communicating with the rest of the car ? Or some other module ?
Old 06-05-2019, 03:22 PM
Mein Auto: '11 328i
I have had zero issues. I did do it because of the combox (later version of MULF thats responsible for allowing hands-free Bluetooth and playing music from USB flash drive ) failure.
I change the vehicle order, removing all the telematics, bluetooth, handsfree, etc.... and recoded several modules to get rid of the SOS error. Once I had just the radio working ( FM radio and CD only), I swapped everthing and haven't looked back. I still have the radio and will hold onto it in case an issue arises. I never had iDrive.
I installed a Pioneer AVH-2330NEX using a PAC audio Pro RP4.2-BM21, which connects to the CANBUS and allows the steering wheel controls to be custom programmed and it comes with a chime solution. It also makes connecting the preamp outputs to the car plug and play. I made custom cables to be able to use the factory hands free mic, AUX and USB ports....pretty clean setup. I can close my garage door using my voice via android auto. I have some notes on it somewhere if you're interested.
I have since modified the VO again and coded to get rid of the RDC module (swap TMPS for FTM) so I can run wheels without sensors and didn't have any issues.
Old 07-05-2019, 09:44 AM
UPDATE: OK, I know I said the speakers sounded good when they were installed, and then they got twice as good after a few hours of running. I'm at ~15 hours now of the speakers running, and all I can say is WOW. These things sounded like total $H!T beforehand (in comparison). The clarity and crispness has really developed in the last 2 to 3 hours of run-time, and I have noticed the max volume seems to have gone up as well (it's "louder" at max volume than it was previously). The factory amp still sucks, but these speakers are nothing short of phenomenal.
TBH, these speakers rival the premium Individual Audio package that BMW offered on the E90 (thanks to Zeichen311 for explaining that package to me). Yes, they're that good. I'm definitely happy with my purchase, and I'm sure I'll be even happier as I replace the amp, and, let's be serious, eventually replace the subs under the seats.
Old 07-09-2019, 01:35 PM
ldusseau39 ldusseau39 is offline
Mein Auto: 2010 328xi
Get the Ghost Subs
I did a full Bavsound upgrade, adding tweeters to the sail panels. It sounded obviously better but not fantastic. So I decided to add the Ghost Subwoofers; Best. Decision. Ever. The midgrade and bass punch is fantastic. You cannot talk over it when you crank the volume, but it doesn't distort. Nice, clean, loud music.
Koni Special Active shocks and struts
Full Bavsound Speaker& Sub Upgrade
PIAA Extreme White H7
LUX LED Angel Eyes
Black Powdercoat 17" OEM Wheels
Bridgestone Pole Position (summer) Blizzaks (winter)
Old 07-09-2019, 02:35 PM
Nice. Did you wind up doing the amp as well ?
Similar Threads
Bavsound Stage 1 Upgrade and JL Amp review julioengineer Car Navigation, Audio & Electronics by BAVSOUND 4 03-18-2015 10:31 PM
BavSound Ghost Subwoofer review and installation guide raichean Car Navigation, Audio & Electronics by BAVSOUND 0 02-13-2015 05:33 PM
Stage 1 BavSound HK Upgrade Review for FXX Cars minn19 F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 44 02-11-2015 08:52 AM
BavSound Review jgbackes 7 Series - F01 / F02 (2009 - 2015) 4 01-20-2015 09:49 PM
BavSound stage 1 review and installation guide raichean Car Navigation, Audio & Electronics by BAVSOUND 4 08-19-2014 03:35 AM
