List of common water leaks? - Bimmerfest - BMW Forums
Old 05-16-2019, 08:22 AM
DFI-9 DFI-9 is offline
Mein Auto: 2003 530i
My first real project for my E39 is to make it waterproof, but I can't find a list of common water leaks...
I've read about doors and sunroof, but I assume there are others.
Current issues:
Water on the back floor Doors
Water getting into my LCM - ?
Having to start in neutral if in heavy rain - ?
Any advice for these issues would be appreciated, but I would love a list of everything I should look into when it comes to waterproofing. Thank you much!
Old 05-16-2019, 10:12 AM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
Another source is water can leak through the tail light gaskets. Usually simply removing the tail lights, clean the back of the lights and the mating surface of the car, and carefully reinstall and snug up the mounting nuts, and all is good. In rare cases, you might have to replace the gaskets. One has to be careful not to overtighten the nuts, being set in plastic, you can break the studs out of the light.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear chassis braces, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 05-16-2019, 12:17 PM
540fan 540fan is offline
Mein Auto: 2001 540iT
Check sunroof drains and clear them of debris.
Had them plug up on a 745iL and water everywhere inside.
Old 06-16-2019, 07:23 PM
canam8 canam8 is offline
Mein Auto: 2002 bmw 525i
Neutral problem may be your boot on the wiring harness. Mines dry rotted and I was also having issue until I went into a car wash and got the under carriage cleaning and it put my car into limp mode. That's when I found out after looking underneath that my boot looked good at a quick glance but soon as I touched it it crumbled to pieces. I dried the harness and inspected all the wires. Put it back together and used a good silicon and put a thick coat all around it and let the car sit for a couple days. I haven't had any trouble since and that was 8 yrs ago. Still driving the car. It has 475,000 on it
Old Yesterday, 01:10 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
wow! half a million.. Im jealous
Specializing In Breaking Things Professionally
15486372<-----
Old Yesterday, 12:33 PM
MRX9989 MRX9989 is online now
Mein Auto: 01 530i
I had moisture get into my glove box/general module/light control module area through the trunk DME relay box. The box was not completely sealed. The trunk will get moisture if the trunk lid harness gasket is failing.
Similar Threads
The new BMW M4 GTS - Special edition M4 available for the first time in the US tim330i F80/F82/F83 M3 and M4 (2015 - Current) 22 02-01-2016 05:44 PM
PSA: reminder to clean out debris under cabin filter LHS gmak2012 E39 (1997 - 2003) 47 06-27-2015 07:33 AM
Need help to diagnose a faulty water pump 2006 E60 greengeco E60 / E61 (2004 - 2010) 34 03-06-2015 11:42 AM
Does anybody know how to remove the air intake box? zabrak999 E39 (1997 - 2003) 14 01-12-2015 03:55 PM
The H2O challenge RKT BMR Off-Topic 25 03-10-2006 11:09 AM
