HELP E93 top stuck in trunk only used 1 time - Bimmerfest - BMW Forums
Old 05-22-2019, 01:45 PM
cwc5150 cwc5150 is offline
Mein Auto: 2011 E93 335i
hello this is my first time posting on any forum (please be kind)
i just got a 2011 BMW E93 335i on my way home from just getting the loan from my credit union so i haven't even made payment yet. I put the top down all seemed fine went to go home. when i got home i tried putting it back up. windows went down but rear module didn't move, windows and trunk wouldn't move and red light on convertible switch would blink, dash displayed red convertible top symbol that says top wasn't finished. when I hit the switch the other direction it allows the windows and trunk to open and the blinking light and dash display both turn off. if the turn the engine off i can hear a lock or something move but cant see anything move. I've changed both salmon relays with no change. fluid is above the + symbol. I own a Bimmergeeks cable and have both of there apps. I also bought a dedicated laptop with all the BMW software like ISTA+ I'm not sure I fully understand the programs but think I got the most of it. I ran some test with the hall sensors and switches. but nothing stood out. no errors codes other than footwell module
Old 05-22-2019, 04:50 PM
Glenpointe Glenpointe is offline
Mein Auto: M3 and Saturn VUE
I have exactly the same problem. I checked all the fuses and replaced the salmon relays, but no changes. I believe the footwell module (lighting control module) causes the top not to operate properly. The hardtop module gets inputs from other modules before it lower/raise the top. Unplug the footwell module for 5 minutes and plug it back, it may reset the module and allows the top to operate. Try it and let us know.
Old 05-22-2019, 06:58 PM
Ok I unplugged all 3 wire harness for about 40 minutes then plugged back in but no changes
Old 05-22-2019, 07:13 PM
Open the glove box. Twist of two screws and remove the back cover you will see the fuse box. Check the fuses to see if they are OK. By the way, when you try to raise the top, did the trunk lid open up?
Old 05-22-2019, 07:29 PM
i already checked every fuse a while back when it first started. no it dont move but i do hear i think the locking latchs unlocking but thats it. i think it could use some lube but i dont see a way to access the locking latchs without the rear module being open
Old 05-23-2019, 06:24 AM
My 2011 335is with 40k miles, but has a lot of issues. It's my third BMW and will be my last.
Old 05-24-2019, 06:18 AM
I understand I bought this car and only got to use the top one time down with less than two tanks of gas and already have other problems as well
Old 05-29-2019, 03:34 PM
I replaced the footwell module, the top operates normal now.
Old 05-29-2019, 04:27 PM
Did your windows go down before you changed your footwell module
Old 05-29-2019, 04:29 PM
Also did get a new footwell module and reprogram it or just get the old one updated
Old 05-29-2019, 04:45 PM
my windows stopped working after the footwell fried. It's under warranty for 10 years and 156K miles. I had it replaced for free.
Old 05-29-2019, 07:36 PM
Oh ok that's great news good for you glad to hear it fixed your issues. I wonder if mine is also bad because all my windows work but when I use ISTA + is reads 1 or 2 in the wrong position if I play with them a little the show the correct position but still dosen't fix my RHT
Old 06-13-2019, 09:01 PM
Got foot well module replaced with no cost for me dealership did it with no appointments with next day results. But my hard top still doesn't work
Old Today, 05:13 AM
roadkillrob roadkillrob is online now
Mein Auto: 325CIC, 335CIC
Maybe this document will help you - also have you tested the salmon relays, they are a common failure point - they are by the pump, a bit hard to get to I would assume with the top stowed but cause the pump not to run. Attached is the how it all works document and the sequence of things etc.
2008 335i Vert Montego/Saddle/Grey Poplar
2014 Mercedes C63 AMG Edition 507 Polar White
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
2019 X5 M-Sport Phytonic Blue/Ivory Extended Merino Leather - On Order
Old Today, 09:58 AM
I cant retrieve the link its says its broken. I actually bought 2 new salmon Relays first with no changes. Not sure where to check next. Was thinking about paying the dealership to manually close it. With low hopes it could correct it self. If not at least I would have better access to most of the components and I'll try lubrication.
Old Today, 05:16 PM
It works for me to download the file, doubt it is lubrication if it doesn't move at all, you can try unplugging the top module it is behind the passenger side back seat side panel area.
