Strut and shock replacement on 2003 540 M-Sport. - Bimmerfest - BMW Forums
Old 06-14-2019, 08:20 PM
Santaclaus4 Santaclaus4 is offline
Mein Auto: Two 2003 540i Msport's
I badly need to replace the shocks and struts on my project car and I'd like to keep it as stock as I can to keep it simple.
It has the 705 M-Sport suspension package.
FCPEuro shows Sachs 556-838 for the 2003 sport (704 suspension) for $172.
They show BMW 31312229612 for the 2003 M-tec II (705 suspension) for $506.
What's the difference besides price?
I know there are alternatives but I'm less certain about them. I know people have mixed results with aftermarket.
2003 540i M-sport
If you put cheap parts on your car, you'll soon have a cheap parts car.
The law doesn't determine right from wrong. They are unrelated.
Old 06-15-2019, 12:33 AM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
No difference other than price and the BMW logo. Go with Sachs.
But.....what is wrong with your original struts and springs ?? Keep them.
<=E39=>
Old 06-15-2019, 06:42 AM
bmdubya1198 bmdubya1198 is online now
Mein Auto: '99 528iTA Sport
For the most original ride quality, go with the Sachs. No sense in spending the extra money on the genuine BMW struts, they're literally the same thing. If you're looking for an upgrade, I highly recommend Koni struts. I don't have them on the BMW, but I have their STR.T struts in my V70R and I'm really happy with the ride. Firmer than stock, but not too harsh.
As far as the suspension code, I'm not totally sure about the differences between them. The struts are likely similar enough that you'd never know the difference, but I can't say for sure.
Alex
1999 528iT Sport M52TUB28- 2-2-1999 240k+ miles
--Alpinweiß III/Sandbeige
2004 X3 2.5i- M54B30 swapped
--Titansilber/Hellgrau
2006 330i N52B30
--Alpinweiß III
2000 Volvo V70R Manual swapped, daily driver
1991 Volvo 944 Turbo
1992 Volvo 245
Old 06-15-2019, 11:57 AM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is online now
Mein Auto: M550i, 540M-Sport, Scud
The M-Sport Suspension II as used on the 2003 540 M-Sport used M5 shocks and struts. That is the reason for the huge cost difference. Up to you if you wish to keep it original or not. But much of the mystic/allure of the 2003 540 M-Sport was the many special features and those shocks/struts where one of them. I verified the part numbers when I removed mine to install coilovers. Part numbers came up as the M5 parts
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 06-15-2019, 04:08 PM
It's my project car so I don't "need" to keep it totally stock. I'd like to keep it close to stock to keep it simple. The shocks and struts that are on it currently are totally worn out. I noticed it when I was replacing the front and rear suspension arms and ball joints. The struts have oil leaking and running down the whole assembly. The rear shocks have an oil smudge at the top so they are just starting to leak.
With all the new parts and new tires (and cooling system), I finally felt it was safe enough to actually drive. The shocks and struts are so worn out the car rode like a 1970's Chrysler. Lumbering and floaty.
I don't want to replace the springs, just the dampeners and I want it to be as "plug and play" as I can.
2003 540i M-sport
Old 06-15-2019, 04:09 PM
Has anyone dealt with Schmeidmann and overseas shipping to the U.S.?
2003 540i M-sport
Old 06-16-2019, 06:29 AM
4thBMW 4thBMW is offline
4th BMW
Mein Auto: 2002 540iT Sportwagon
yes, in my quest to find a so called good price for a OE front strut replacement
on my sport wagon...Stay the hell away from Schmeidmann... Santaclause. That said, Sachs spec'd me with those Advantage 556-838 ft. strut replacements for my 2002 (S227A) suspension...in writing. Bought those: wrong! The were awfully harsh, the wrong strut insert. The SACHS Advantage 556-636 work fine in my car now. There used to be much confusion of this much to my dismay and wallet. Those red label SACHS advantage inserts you mention above and that I used are for the E39 sedan with sport suspension (not the 2003 E39 sedan with the M5 parts). Dare I say ask SACHS? I'd say ask as you are doing here in the forums and maybe give these KONI's a try on lowest settings and creep into how you like them set after a few miles I've used KONI's for 35 years and have been able to dial them in to happily meet my 'custom' needs on several non-BMW applications.
Old 06-16-2019, 07:08 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
You are on the right track. Don't replace springs unless physically broken. They don't "wear out".
2002 530i
