AGENCY POWER TOP MOUNT INTERCOOLER - SILVER BMW F80 M3 | F82 M4 | M2 Comp - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 06-21-2019, 05:46 PM
[email protected] mike@x-ph.com is offline
Mein Auto: FBO 07 e92 335i
Intercoolers are one of the most important parts of a forced induction system. As air becomes more compressed, its temperature increases. Hot air is less dense than cold air and hot air is more susceptible to detonation. The job of the intercooler is to keep charge air temperatures low and consistent. For S55 powered vehicles, BMW uses an air-to-water intercooler. If you enjoy driving hard on canyon roads or the occasional track day, the OEM intercooler quickly becomes a performance bottleneck. Even daily driving can become a challenge for the OEM intercooler in hot climates. The OEM intercooler is very susceptible to heat soak, which results in high charge air temperatures and ultimately less power. The Agency Power F8X intercooler fits into the stock location and offers significantly better cooling compared to stock. Intercooler volume is increased by 61% which results in lower and more consistent charge air temperatures. It's designed as an OEM replacement and doesn't require custom work for installation. With lower and more consistent charge air temperatures, the chance of detonation is greatly decreased and power is increased.
Features:
  • 61% Larger Than Stock
  • Lower Charge Air Temperatures
  • Consistent Charge Air Temperatures
  • Reduced Chance of Detonation
  • Reduced Change of Heat Soak
  • Cooler Air = More Power!
  • Available in Silver
Fitment:
  • BMW F80 M3
  • BMW F82 M4
  • BMW F83 M4
  • BMW F87 M2 Competition (S55)
Old 07-11-2019, 09:16 AM
Narcosis Narcosis is offline
The dude abides
Mein Auto: 335xi
What are your thoughts on upgrading the heat exchanger along with the IC?
2010 335i coupe
Old 07-11-2019, 12:26 PM
I did it on the shop's M4, and the car is much more responsive in the Las Vegas weather
