HPFP recall question - Bimmerfest - BMW Forums
Old 07-11-2019, 05:57 PM
Britneyizer Britneyizer is offline
Mein Auto:
Dumb questionJust wondering why the HPFP was failing. Was it completely shutting off the fuel flow or was it sticking open and flooding the engine?
Old 07-11-2019, 06:53 PM
floydarogers's Avatar
Pedant and Curmudgeon
First, we have to know if you even have an HPFP - only the 335i did (if you have a 328i you don't have one to fail.)
Second, they don't "stick open". They fail and don't presurize the "fuel rail" that leads to the injectors. (Which could be said to "shut off fuel flow".)
In either case, the "recall" for them has been completed for several years, so if you have a failing Low Pressure fuel pump or HPFP, it's not covered by any "warranty" and you'll have to pay to get it fixed, if that's what is broken. (Is anything broken?)
Old 07-11-2019, 08:30 PM
Mein Auto:
I do have a 2008 335xi. I'm having problems starting it if it sits for more than 4 hours without being driven. There are not any codes and the check engine light doesn't come on. It seems to flood if I start it from a cold start. I can smell gas anyway. I was thinking the HPFP may be over pumping fuel and drenching the plugs. My 1st plan is to change the plugs and coil packs and see if that helps.
Old 07-12-2019, 12:13 PM
Why replace the coil packs? They don't go bad very often, are expensive, generally set an SES code if they do. Waste of $, especially if you're tracking a fuel problem.
Check your pressure relief valve on the fuel rail - seems like you're leaking down when you shouldn't. Or perhaps you have a slight leak somewhere in the rail assembly.
Old 07-12-2019, 01:29 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Breaking in the Pony
Mein Auto: 19 Mustang GT / 05 Tacoma
The most common symptom of an HPFP failure was long cranks at startup, as a result of inadequate flow at start. I believe there may have been some limp mode situations due to inadequate / low pressure flow as well. I don't recall any "dead" HPFP failures, but that doesn't mean they didn't happen. Codes to look for include 29DC, 29F1, 29F2, and 2FBF.
The biggest solution was for BMW to reprogram the car's ECU so that the pump primes when the car wakes up, rather than when you first press start. There should be a (yellow?) sticker in the driver's door opening showing that the recall was performed.
Prior 44 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92 / 2015 BMW M235xi xDrive F22
Old 07-12-2019, 07:45 PM
The biggest solution was for BMW to reprogram the car's ECU so that the Low Pressurepump primes when the car wakes up, rather than when you first press start. There should be a (yellow?) sticker in the driver's door opening showing that the recall was performed.
Zooks' post has more info than I presented regarding HPFP failures.
