Loose BMS intakes? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 07-29-2019, 07:07 AM
Like-an-owl Like-an-owl is offline
Mein Auto:
Loose BMS intakes?
Just picked up the bms elite intakes for my car but couldn't help notice how loose everything fit together. For example, when placing the blue cone filters onto the pipes, there was nearly a full inch gap all the way around the thing almost as if they are the wrong size. Once I tightened it all down it fit snug but I couldn't help but feel like that amount of tightening shouldn't be necessary. Also, on the short intake side, trying to get the intake to sit correctly was nearly impossible. There is some wiring wrapped in heat tape that is set very firmly in place that was almost directly in the way of the pipe. Anybody install these on their own and have similar problems? Any solutions or tricks? Any help is appreciated.
Old 07-29-2019, 07:34 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
CAI are worse than snake-oil because the snake-oil gets on the MAF and will ruin it.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 08-10-2019, 09:13 AM
ard ard is offline
Resident Curmudgeon
Those are a scam. Your performance will be worst. Sure you will get excited seeing the blue cones when you open the hood, but they are horrible designs. Heat soak will kill you. They are sucking hot air in from around the engine.
There is a sucker born every minute is most finely demonstrated with air filters and intakes.....
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
