2003 bmw 530i - Bimmerfest - BMW Forums
Register FAQ Community Calendar Today's Posts Search
Old 08-01-2019, 07:30 PM
530beem 530beem is offline
Mein Auto:
2003 bmw 530i
I just bought a 2003 bmw 530i in good condition but it has a few issues. The radio cuts in and out no matter if I'm driving or in park. It barley started today. The radio will cut out as if I pressed the volume knob, and the steering wheel will sometimes move a little up or down. It barley started today but it's annoying. Any help ?
Old 08-02-2019, 05:47 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
I moved your question to the E39 forum (5 Series, 1997-2004) so you can get model-specific help.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 08-02-2019, 09:31 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
1. Do an iggy switch test: When the gremlins appear, turn on the passenger visor light. If that has an effect, consider replacing the iggy switch.
2. Pull up the front passenger carpet. The power panel underneath may be corroded from water ingress.
BTW, "barley" is one of the ingredients in beer brewing.
Old 08-02-2019, 01:25 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
great soup/stew ingredient as well.
99 528i 5sp sport
be alert...the world needs more lerts
Old 08-02-2019, 02:25 PM
Hitdog540's Avatar
Hitdog540 Hitdog540 is offline
Hitdog540
Mein Auto: '03 540/6, '15 550
My grandmother used to make the best barley soup!
Old 08-02-2019, 03:32 PM
Mein Auto:
So turn the passenger light on when that starts to happen? What am I looking for, or what should it do? And the ignition switch correct?
Old 08-02-2019, 03:33 PM
Mein Auto:
And Lol typo barely**
Old 08-02-2019, 03:52 PM
Yes, iggy = ignition switch.
This test, while not conclusive, should have some effect on the symptoms, and suggests a faulty switch.
BTW, tell us where you live, so it can help the diagnosis.
Old 08-02-2019, 11:16 PM
Mein Auto:
So when I open the slide for the mirror to turn the light on, my radio cuts out.
Old 08-02-2019, 11:25 PM
Mein Auto:
Does that mean it's most likely my ignition switch ?
Old 08-03-2019, 05:25 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
Only after you heat it and then it becomes malt. Btw, hops sux!
Old 08-03-2019, 06:18 AM
djbecker djbecker is offline
Mein Auto: e30,e34,Z3,e39
Yup, that's the sort of wonky behavior that points to a bad ignition switch. The extra load on the switch contact causes other circuits to do unexpected things.
It's possible to clean the contacts, but it's enough work to access that most people just replace the switch rather than risk another failure.
Old 08-03-2019, 08:03 AM
528iAut 528iAut is offline
Mein Auto: 1996 528i
Just search for bmw e39 ignition switch test....
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 08-03-2019, 10:16 AM
Mein Auto:
Just ordered a new one off of oreillys hopefully it solves my issue I appreciate it guys !
And I forgot to mention I had checked all my fuses and they're ere fine.
Old 08-03-2019, 04:13 PM
Mein Auto:
I read that the ignition switch could also cause my windshield wipers not to work is that correct ?
Old 08-04-2019, 06:13 AM
cn90 cn90 is offline
Do NOT use OReilly brand.
Genuine BMW ign switch is $60.
Or get a used one from jy.
Or clean the contacts yourself (info in forum).
Old 09-08-2019, 08:26 AM
Mein Auto:
I have replaced the ignition switch and all is well, I wanted to drive around for a month or so after I swapped it to be sure that the issue was gone
Old 09-08-2019, 03:25 PM
When you get help everything is easy, it is when you do not get help it can be difficult.
Did you do the e39 ignition switch search or what? Lots of things to learn.....
Old 09-10-2019, 07:37 AM
Mein Auto:
Yes I did the "ignition switch test " lol
