Problem finding 08 328i bmw sedan water pump fuse - Bimmerfest - BMW Forums
Old 08-14-2019, 03:31 PM
Skyler carson Skyler carson is offline
Mein Auto:
Hey I'm having a hard time finding the water pump fuse inside my ECU fuse box. Every forum I've seen have had a green 30a and I don't even see one in mine. I've done the bleed test and the water pump isn't even coming on. A few months back I had the thermostat and water pump changed and it worked fine but It recently started overheating again. Any help would be greatly appreciated
Old 08-14-2019, 04:16 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
I moved your question to the E90/91/92/93 forum (3 Series, 2006-2013) where you should get model-specific help.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 08-14-2019, 04:29 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
georges links
https://www.bimmerfest.com/forums/at...9&d=1539905743
Old 08-14-2019, 04:59 PM
Mein Auto:
Originally Posted by ctuna View Post
Thank you but I tried downloading the service manual earlier on and the page doesn't load for me. However I was able to locate the fuses, which in my model the coolant pump fuses are in the glove department set of fuses. Both was replaced however my water pump still isn't kicking on. Not sure how to figure out the issue.
Old 08-14-2019, 05:18 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
https://www.newtis.info/tisv2/a/en/e...ooling/vBAgN29
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 08-14-2019, 09:45 PM
gbalthrop gbalthrop is offline
Mein Auto: 2007 328xi E91
Originally Posted by Skyler carson View Post
...I'm having a hard time finding the water pump fuse inside my ECU fuse box...I've done the bleed test and the water pump isn't even coming on. A few months back I had the thermostat and water pump changed and it worked fine but It recently started overheating again...
Only fuse in the E-box under the hood on your 2008 328i is F07 (40A) which powers the VVT Relay (K6319).
There are TWO fuses (on JB/Junction Box fuse panel) related to Coolant Pump Operation on your 2008 328i E90 as shown in the following TIS Schematic. F33 (40A) is battery powered (Terminal "30" above fuse) and provides power to the Coolant Pump Motor. F37 (30A) is Terminal 87-Switched (Terminal "87" above fuse) and provides power to the Thermostat Control and the Coolant Pump Control:
Here is the "Installation Location" for fuses F33 & F37:
https://www.newtis.info/tisv2/a/en/e...lim/1VnYmxVJ04
Check both of those fuses & let us know if you still have NO PUMP BLEED ACTIVATION. If you still have no pump activation, let us know if you have ANY Scan Tool (although you will probably need INPA/ISTA or some BMW-specific Scan Tool to read Coolant Pump Codes 2E81 thru 2E85), and if you have a multimeter, and we can suggest further diagnostics. ALSO, please let us know of any work done under hood or in battery area in days before overheating.
George
Old 08-14-2019, 11:09 PM
08 335Ci 08 335Ci is offline
Mein Auto: 2010 335 M sport
A common problem is corrosion in the pump connector. It's possible some coolant got into the connector and wasn't cleaned out. Another common fault is the connector wasn't fully locked in place and is now disconnected.
No matter how fast I go, there's always someone slower in front of me.
2010 E92 335 M Sport, Titan Silver Metallic, Steptronic, JB-4 G5 ISO, WMI, 3.5 Tmap (22 psi boost), BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC, Pedal tuner, Escort Max 360
Gone, but not forgotten ( totaled)
'08 335 E92, M-Sport suspension, 6 sp auto, w/paddle shift
CCA Member 109065 since 1993
CQ ... CQ...Kilo Charlie 3 Bravo Whiskey Zulu calling CQ
Old 08-17-2019, 09:09 AM
GeorgeBush234 GeorgeBush234 is offline
Mein Auto: Passat
have you checked the spark plugs they relate to the cooling system a bit.
Old 08-17-2019, 09:11 AM
Mein Auto: Passat
have you checked your spark plugs they relate to the cooling system a bit.
