540i Expansion Tank - Bimmerfest - BMW Forums
Old 08-30-2019, 05:44 PM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
540i Expansion Tank
Hello everyone!! The time has come for yet another expansion tank. I cant remember what brand I used last time. Over $140 I don't remember for an OEM BMW tank. I norm get my parts from FCP as the warranty is the chit but didn't get it there last time. They have one for a fraction of the price but the reviews are shaky as its a China made part. Also this part includes a new sensor as the OEM BMW does not. https://www.fcpeuro.com/products/bmw...-17111741167-1
What ya'lls opinion? Also should I replace the cap,bleed screw and sensor as well? Thank you for any info offered.
540i ~ Full LED Interior l MTEC AEs/Plate LED l Akebono Euro l Carbon Fiber Kidneys/Emblems l Hankook v12 l 19" Black MRR GT-1
X5d ~ Akebono Euro Pads l Zimmerman Rotors
Old 08-30-2019, 10:37 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
I continue to use Behr, and have had no issues with them. Yes on replacing the cap and bleed screw (I use the brass aftermarket one). Sensor is fine, but as noted, it can hang up. I didn't realize until reading the reviews just now, that excess flashing on the stick is the reason, may have to look at mine again, and take care of that.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 08-31-2019, 01:30 AM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
I also use Behr -it is actually made in China for Behr !
Replaced the cap and the bleed screw, and expect it to last a couple years, or about 20 K miles....Your mileage may vary.!!
<=E39=>
Old 08-31-2019, 10:55 AM
atobe atobe is offline
Mein Auto: 00 528, 01 540
Yeah replaced mine few weeks ago, Behr/Hella from FCP saids made in china but stamped 04/2019 so it's fairly new. I kept getting the check coolant level error, old sensor was going bad. Where'd you get the brass bleed screw from? I felt like I was going to break it installing it onto the new tank.
Old 08-31-2019, 12:12 PM
https://www.autohausaz.com/pn/17111712788AFT
I have had my brass bleed screw for about 10 years now. I noticed recently it started spitting/leaking coolant. Condition looked fine, including the o-ring, though the o-ring did look rather flattened upon closer inspection. I replaced o-ring with a new nitrile o-ring from one of those assortment kits from Harbor Freight I had in my tool drawer, and it is working great again.
I think the plastic bleed screw is totally fine. You just need to replace it (along with the cap) each time you replace the expansion tank. Problems arise when you try to reuse the cap and screw.
Old 08-31-2019, 12:44 PM
Thank you for the info buds
Old 09-05-2019, 09:04 PM
So I just fixed my 5 month old Behr expansion tank that would give me a "low coolant" warning every month...from reading the reviews on FCP Euro (others having same issue), I found the problem is a tiny bit of excess plastic flashing on the float stick, reported by one observant user. This catches on the guide, which then holds the stick down, causing the warning. So today I did a check, and looked more closely and sure enough, saw the same problem. I played with the stick to confirm I could make it stick, and hang up on the bit of flashing. So I pulled the stick up, and using a long bladed, sharp knife, I trimmed that crap off and fixed!! Friggen Chinese quality control. Otherwise the Behr seems to work just fine, just watch out for this production issue.
Old 09-05-2019, 09:46 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
Just to add my $.02 about the brass bleed screw(s) is the first time you try to tighten or loosen the plastic bleed screw & the head comes off, but not the threads, you'll switch to the brass one & never go back. My vote is just to buy a brass one & forget about it forever. Oh, until it's time to replace the expansion tank & you need to grab the brass screw from the old one & put in the new one.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 09-06-2019, 08:14 AM
Santaclaus4 Santaclaus4 is offline
Mein Auto: Two 2003 540i Msport's
Completely agree with this.
2003 540i M-sport
If you put cheap parts on your car, you'll soon have a cheap parts car.
The law doesn't determine right from wrong. They are unrelated.
Old 09-06-2019, 09:44 AM
So I just fixed my 5 month old Behr expansion tank that would give me a "low coolant" warning every month...from reading the reviews on FCP Euro (others having same issue), I found the problem is a tiny bit of excess plastic flashing on the float stick, reported by one observant user. This catches on the guide, which then holds the stick down, causing the warning. So today I did a check, and looked more closely and sure enough, saw the same problem. I played with the stick to confirm I could make it stick, and hang up on the bit of flashing. So, pulled the stick up, and using a long bladed, sharp knife, I trimmed that crap off and fixed!! Friggen Chinese quality control. Otherwise the Behr seems to work just fine, just watch out for this production issue.
THX for the info. Parts just came in today. Will check my tank for that plastic on stick. Cant wait to drove my baby after sitting for a week
Old 09-06-2019, 04:24 PM
Interesting, if that's the case then I'll have a spare exp tank. I'll have to check both of mines. It was giving the error once a week or something like that.
Old 09-06-2019, 06:43 PM
Let us know if you spot this fault or not...
Mine was more intermittent, but do report back your findings from inspecting the float stick
Old 09-08-2019, 07:16 PM
THX bud for all the help. All parts installed,up and running again I could not find the spot tank failed. If helps any I spotted the leak from under the tank after full warm up. It was a flowing leak. That being said the leak started a few moths ago but did not know where I was losing coolant. Thank you again buds
Old 09-09-2019, 10:13 PM
By "fault" I was asking you to look for the manufacturing "fault" or defect in the float stick, that has the molding flash as pictured in my post above...
Old 09-10-2019, 06:46 PM
Yes I can confirm the fault in my float stick. Not only did it look like your picture but other sides at the same place where also fault. Thing is I never got a bad reading because of that. Also I could not find a date code. I hope this helps.
Old 09-10-2019, 06:48 PM
Thank you, just wanted to confirm there is an ongoing manufacturing defect in this part. At least it is a simple fix.
Old 09-10-2019, 06:58 PM
Thank you for all your help through the years of ownership bud~~~Hats off!!!!
