Should I change the transmission fluid and filter at 156,000 miles? 2003 bmw 530i - Bimmerfest - BMW Forums
Old 09-04-2019, 05:25 PM
iLmon3y iLmon3y is offline
Mein Auto:
My torque converter went bad so I have to replace that but Iím thinking about changing my atf fluid and filter as well. My car has high mileage so Iím nervous that it might ruin the transmission more. So far, it shifts fantastically but I have no idea how often the previous owner changed his transmission fluid if he even did it at all. What do you guys think?
Old 09-04-2019, 05:41 PM
CSMBlack-540i CSMBlack-540i is offline
Search, Read, THEN Ask
Mein Auto: CDN 98 540i M62 3.15
If you have no idea what's in there, all the more reason to do it and know for sure what's is in there. Just make sure you follow the various DIY write-ups and do it right with the right fluid.
That said, I drained and refilled mine twice at 110k miles nearly 10 years ago and still shifts fine.
Old 09-04-2019, 05:45 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
Yes. Drain and fill, drive a few miles, then drain and change filter, gasket and fill. That should get you to around 70% fresh fluid.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 09-04-2019, 05:49 PM
bmw blue's Avatar
bmw blue bmw blue is online now
Mein Auto: 2000 BMW 528i Steptronic
I think you should state what year and model BMW you have for starters.
Changed mine at 117,000 miles and again at 165,000 or so miles.
Old 09-04-2019, 05:59 PM
Title of posts says "Should I change the transmission fluid and filter at 156,000 miles? 2003 bmw 530i"
Hence 2003 530i is my take on model and year
Old 09-04-2019, 06:00 PM
Mein Auto:
Lol I edited the post after he said that
Old 09-04-2019, 06:07 PM
Might be easier just to edit your profile/garage/mein auto where it should be so it doesn't get asked over and over each time you start a new thread.
Old 09-04-2019, 06:38 PM
Santaclaus4 Santaclaus4 is offline
Mein Auto: Two 2003 540i Msport's
If you are replacing the torque convertor, just drain the rest of the fluid from the transmission and replace the filter at the same time. No need to flush and fill several times since the purpose of that method is to replace the fluid that won't drain from the torque convertor.
2003 540i M-sport
If you put cheap parts on your car, you'll soon have a cheap parts car.
The law doesn't determine right from wrong. They are unrelated.
Old 09-05-2019, 09:02 AM
Cirrusnine Cirrusnine is offline
Mein Auto: 2 matching 2003 530i's
And, while you have the torque converter out, you will have easy access to the torque converter seal, which would be a good item to replace if you plan on keeping the car long-term.
This seal tends to leak over time and may cause a cascade of bad events due to low transmission fluid.
part #24201423382 - available at FCPEuro or your favorite BMW dealer.
Old 09-05-2019, 12:14 PM
Agreed, I missed that in my haste of reading the post.
Old 09-05-2019, 04:48 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Won't a rebuilt TC have a fresh seal, assuming he won't go to a breaker for a use part (maybe he will)?
Old 09-05-2019, 07:19 PM
That's why I didn't quote you. I didn't want it to look like I was poking at you.
2003 540i M-sport
Old 09-05-2019, 07:21 PM
No, the seal goes on the transmission side and will not come with a new torque converter.
2003 540i M-sport
