Driveline Experts Please Chip In - Bimmerfest - BMW Forums
Old 09-05-2019, 05:05 AM
mtl_dom mtl_dom is offline
Mein Auto: E39 1998 528i (b.d.07/98)
I've been chasing the source of squeaking brakes on rear driver side.
Triple checked brakes. All's good. So I jacked the car up, and started it up. Looks like the caliper is moving from side to side when the wheel turns. So I thought it must be the axle shaft pushing on the wheel bearing and carrier. Took out the shaft, cleaned it and regreased. Same issue. Swapped it out with a new FEQ unit. Same issue. Could it be a bad diff?
When I last checked, there was some clicking going on. It's hard to pinpoint the exact location of the noise, because the whole half shaft is resonating, so I'm planning on disconnecting the axle shaft today to isolate the diff. Anyone seen this before? Car has 105k miles (170k KM). Pretty sure it's only on one side. Brakes are new btw.
Old 09-05-2019, 07:45 AM
CSMBlack-540i CSMBlack-540i is offline
Search, Read, THEN Ask
Mein Auto: CDN 98 540i M62 3.15
Seems like quite a bit of suspension movement just from the wheel rotating at low speed. Was the rear suspension ever overhauled? Movement of the driveline could also be a worn Giubo aka flex disc. But, overly worn Giubo also exhibits clunking when releasing gas during acceleration. While movement of the wheel could also be attributed to worn wheel bearings. Hard to really diagnose off a 15 sec video.
Old 09-05-2019, 08:33 AM
Suspension has been changed recently. Wheel bearing as well. Flex disc and CSB are in surprisingly good shape. The rotor is getting pushed out once per rev, making the rotor rub on the outer brake pad, causing the squeaking. I can see the axle shaft move in and out in sync. There's some harsh grinding sound coming from the rear when I'm sitting inside the car jacked up, but it disappears during normal driving.
Old 09-05-2019, 11:03 AM
You can clearly hear the clicking in this video. The low rumble in the cabin doesn't come through on camera though.
Old 09-05-2019, 11:47 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
Time to get old school. Get yourself a wooden dowel and place it against the back of the diff. Put your ear against the other end of the dowel and chase the source of the sound. Just keep the dowel, and your head, away from rotating parts.
2002 530i
Old 09-05-2019, 12:46 PM
Crazy4trains. I forgot I had a stethoscope. Turns out the clicking is not from the diff, but from the wheel side. So Iíll have to strip down the wheel assembly and see how the bearings are doing. Sounds like a job for a Saturday. At least I wonít have to swap the diff!
Old 09-05-2019, 01:24 PM
Originally Posted by mtl_dom View Post
Turns out the clicking is not from the diff, but from the wheel side. So I'll have to strip down the wheel assembly and see how the bearings are doing.
Since it's now narrowed down to wheel side;while checking the bearings, might also want to check rotor for warpage. While doubtful, can always temporarily swap rotor from one side to another to rule that out.
Guess, sometimes even when suspensions and bearings have been changed it doesn't necessarily mean that's not the issue
Old 09-06-2019, 04:55 AM
Appears to me that the caliper is moving but most everything else is behaving as it should. I would remove the wheel, caliper, pads and rotor then thoroughly clean all mounting surfaces and ensure all fasteners are correctly torqued. Maybe the axle shaft is making stuff move but start with the simple stuff first.
2002 530i
Old 09-06-2019, 05:28 AM
I've already removed the rotor and even checked the parking brake hardware, but everything looked good. I'll have to remove the brakes again anyway to check the bearings. New Brembo rotors and Meyle ceramic pads were installed two weeks ago. It's smooth as butter when I brake. I'll report back after the weekend.
Old 09-09-2019, 09:11 AM
After taking off the brake hardware, it appears the bearings are the culprit. Itís really rough when turning the hub by hand. Parts ordered on rockauto. Theyíre the best when shipping to Canada, as broker fees and taxes are included.
Iíll confirm when job is done.
Old 09-09-2019, 09:30 AM
Old 09-09-2019, 10:54 AM
Suspension has been changed recently. Wheel bearing as well. .
After taking off the brake hardware, it appears the bearings are the culprit. It's really rough when turning the hub by hand. Parts ordered on rockauto.
If wheel bearings are culprit after already being changing recently. More info on brand. mileage and vendor of those "new" bearings would help future members to avoid a certain brand.
Old 09-12-2019, 01:55 PM
Quick update: received new Timken bearings. To my surprise, no part of them is made in the USA. Looks like cheap Chinese crap. Given cnnís great write up on replacing the rear bearings, and the pictures on most websites selling these, I thought at least the bearings were made in the US. Looks like Timken is getting the whole thing done in China now, except for the box lol. Should I return the part and just get *** (OEM)?
ID:	864401Click image for larger version
Old 09-12-2019, 03:17 PM
Might want to check out National Wheel Bearing Part Number 512225. Last time I picked them up they were F.A.G. Made In Germany in a Nat'l Box.
There is one on Ebay and if you zoom in on the middle picture, you can make out the word F.A.G. Germany. Assuming the auction is a picture of the actual bearing you get:
https://www.ebay.com/itm/National-51...r/183792899110
Also try F.A.G. 580494 as a possible interchange part since that is also the number stamped on the bearing and matches this auction which also for just one left.
https://www.ebay.com/itm/Wheel-Beari...4/173905908808
Old 09-12-2019, 05:02 PM
bmw blue's Avatar
bmw blue bmw blue is online now
Mein Auto: 2000 BMW 528i Steptronic
German made bearings blow away China's in This simple test, don't just get your bearings and settle for less, get the good ones.
I don't need to tell you which is the German manufactured bearing.
F.A.G. for the win, nothing beats German made bearings.
Beisan Vanos Repair, EMP Stewart Water Pump, Aluminum Water Pump Pulley, Behr Electric Fan, Sachs Fan clutch,
18pc Lemforder Suspension Kit w/Koni Sports+H&R Springs,
E46 Intake Boot W/AFE Dry Air Filter, Conforti Shark Injector,
Liqui Moly Leichtlauf High Tech 5W40 Motor Oil, Pentosin Full Synthetic Transmission Fluid and 75-90 Motul Full Synthetic Differential Oil.
Michelin Pilot Sports (summer), Continental DWS (winter).
190,500 miles and counting.
Old 09-12-2019, 08:19 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
Google search might help in the decision. It appears Timken has been sourcing from China for over 8 or 9 years, so research might show if there are problems with them or not.
I found plenty of threads of people upset they are made in China, but not of any failures or complaints of failures...so maybe they are fine.
I always have used F.A.G. brand fwiw.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 09-13-2019, 05:46 AM
Thanks for the replies. I'll be returning the Timken bearing, and buying F.A.G. from FCP. I believe they're made in Slovakia. Spent enough time on this already, not gonna take chances with Ebay. Just looking at it and feeling the Timken does not inspire confidence. Reason I went with Timken is I think the failed bearing is a F.A.G., but to be confirmed.
If memory serves, I had bought the bearings maybe 3 years ago, and had them installed on my previous bimmer by local garage. When the engine died last year, I saved as many parts I could, including wheel bearings, since they were relatively new (15k miles tops). They sat for a couple months, then installed on my newer bimmer in June 2019. Not even sure when the problem started, as I only noticed after the new brakes 3 weeks ago. So the bearings have a bit of history, but not that much. It's hard to tell which brand with the hub on. To be confirmed.
Why is the hub so expensive??
Old 09-13-2019, 01:36 PM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: e39, e83, e60
sounds like an axle to me
Specializing In Breaking Things Professionally
15486372<-----
Old 09-14-2019, 10:10 AM
Right??? That was also my first thought. But after installing a new axle shaft, the noise is exactly the same. Also the clicking sound disappears when car is on the ground. Squeaky brakes while driving only, and a little shimmy. Kinda thing my mother would never notice it's so faint. I'm not used to hearing that click sound from a bearing, they usually howl when old. We'll only find out the real problem once it's all appart in a week or 2.
