Runs and drives rough when cold. - Bimmerfest - BMW Forums
Old 09-05-2019, 03:59 PM
gvolbs78 gvolbs78 is offline
Mein Auto:
I just purchased a 2003 5 speed and it runs great once driven for a little while. When the car is cold it shakes while idling and the whole car shudders while driving. After about 15 minutes it runs great. It's throwing codes for cylinder 1,3,4 and 6 as well as a multiple misfire code as well a p0174 and p0171. Haven't done anything thing yet. After I check coils and plugs what should I do next?
Old 09-05-2019, 10:33 PM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
[ Check, clean and/or replace the spark plugs, coils and boots on all cylinders.
Clean the MAF (mass air flow) sensor, and the throttle body and cables..
Replace the engine air filter, and the fuel filter.
Change engine oil and filter. ]
Reset the adaptations and test again.
<=E39=>
Old 09-06-2019, 05:59 AM
jbarb jbarb is offline
Certified humanoid
Mein Auto: 2003 530i E39
I was seeing the same codes a while back and turned out to be a bad o-ring for the DISA, causing a leak. My suggestion would be to do a smoke test to see if there's a vacuum leak. (Pretty easy to build with a paint can, some resistance wire and a few other bits)
Old 09-06-2019, 07:38 AM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
+1 on doing a vac leak check
99 528i 5sp sport
be alert...the world needs more lerts
Old 09-06-2019, 11:02 AM
Mein Auto:
I started it up this morning and it ran perfectly. I'll do the smoke test and see what I figure out.
Old 09-16-2019, 05:53 PM
Mein Auto:
I did a vacuum leak test and smoke was pouring out throttle body boot and also the side of the disa. It didn't look like it was the seal but it was coming out next to the electrical connection. Does this mean the disa itself is bad?
Old Yesterday, 05:56 AM
Certified humanoid
The DISA is pretty easy to take out (5-10mins). Do that and check for cracks. For me it was hard to tell exactly where the smoke was coming from, it looked like from all around the DISA but ended up being resolved by replacing the O-ring. While you have it out, also check the flap and make sure it's in good condition. You DO NOT want to drive around with a broken DISA flap.
Old Yesterday, 06:59 AM
Mein Auto:
This is what it looked like. I'll take it out when I get the chance.
