Maximum wheel bolt length - Bimmerfest - BMW Forums
Old 09-12-2019, 01:00 AM
Trnc3 Trnc3 is offline
Mein Auto:
Hello!
I was wondering if anyone knows the maximum length of wheel bolts that can be used before you hit something on the other side (handbrake at the back etc).
The reason I'm asking is because I am installing spacers to my new wheels but can now only use smaller star pattern wheel bolts instead of the regular ones.
I could only find 45 mm bolts of that style available for buy online and I would be installing a 10 mm spacer. That would bring the bolt length to 35 mm if we leave out the spacer instead of the original 25-28 mm. Thats a minimum of 7 mm longer bolt.
The question is, would these bolts fit or will I run out of room?
Thanks.
Old 09-13-2019, 04:55 AM
rdl rdl is online now
Mein Auto: 530i 2003
I don't know the answer but can suggest a method for you to determine it.
Remove a wheel and thread a lug bolt into the mounting hub to the depth your proposed bolts would extend. Turn the hub by hand to see if it clears. Wind the lug in another few mm or fraction of an inch and repeat to see how much margin of clearance you'd have. Front and rear.
Regards
RDL
Old 09-13-2019, 09:41 AM
Mein Auto:
Thanks, probably the easiest way.
I already ordered the 45 mm bolts anyway. Can always angle grind them if needed, I guess.
Old 09-13-2019, 11:26 AM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
Actually seeing might be better, but that requires removing the rotor which meams also removing the caliper.
In the front there is a ton of room but the rear has the e-brake in the way.
From what I remember when buying spacers and extended bolts for a couple of our cars...standard bolts at 28mm go about 3mm into the space which I never measured but I'd guess is about 25mm (roughly an inch), so the front should accommodate close to 50mm without a spacer. The rear is probably more like 35 max without a spacer.
Other things from memory for calculating bolt length, rotor hat and hub flange are about 8mm each. Actual measurements should be taken though as my memory may not be close enough for you safe mounting of the wheels. And your wheels may make a difference so you should put a bolt through one while off the car to measure its thickness..
Sent from my LM-G820 using Tapatalk
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG
1999 740iA - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 330xiA - fXtXeX/son project - now April's car
2008 335xiA - winterbeater Impala replacement
2002 530i/5 - 2.5 years searching...and it is John's car
1989 535i/5 - the spare car
2002 325xiA - to be Charlotte's when she gets her license (?2019?)
