Looking at buying 86 735i - question - need help - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 11-19-2019, 03:11 PM
Henryctx Henryctx is offline
Mein Auto:
So, previous owner left car on battery charger and key in on position. Car pumps fuel to fuel rail but no spark. They replaced ignition coil, distributor cap, car ran fine before parked and put on charger. Thinking they burned out ECU but interested in what else to check. Thinking cps and other sensor are ok.
Old 11-25-2019, 06:29 PM
m735is m735is is offline
Mein Auto: e23, e32, e34, e39
Have you tested the sensors on the tranny bellhouse?
Old 11-25-2019, 06:35 PM
Mein Auto:
Will check both sensors on transmission. I have the ETM and will go through the no start / no spark troubleshooting process I found on bimmerboard's forum.
Old 11-25-2019, 06:36 PM
Mein Auto:
Really hoping the ECU is ok.
Old 12-14-2019, 04:14 PM
Mein Auto:
Update - It was the sensors / ecu is fine. It runs now. Different issue, car doesn't always shut off when key is in "off" position.
