Steel Wheels - Bimmerfest - BMW Forums
Old 12-06-2019, 09:33 PM
SmitteyB SmitteyB is offline
Mein Auto: 2007 328i, 2007 X3
Steel Wheels
Im looking at a set of Steel wheeled snows for my 07 E90 RWD.
The wheels are off a 2017 Subaru WRX, and the tire size is correct for my car. However, I am concerned with the steels that these are on. The bolt pattern is correct, however, I'm worried about the offset. The seller doesn't seem to know much about these.
Am I worrying too much? Or is this as big of a deal as I think it is?
Apologize for the ignorance. I'm a DIY'er with zero experience in tires/wheel buying. Im a OEM kinda guy.
Old 12-06-2019, 10:02 PM
relative4 relative4 is online now
Mein Auto: '08 335xi E90 manual
The offset is stamped on the back of the wheels.
http://www.wheel-size.com
Old 12-06-2019, 10:14 PM
If it is different than my OEM, how big of a deal is it? For instance if the offset is 40mm vs 48mm will I see drastic differences in handling?
Old 12-07-2019, 06:31 AM
Jay Arras's Avatar
Jay Arras Jay Arras is offline
Casual Fanatic
Mein Auto: 2007 530xi 6 speed manual
Basically, the lower the number the more the wheel sticks out. The higher the number the more the wheel sits inside the wheel well. Rims with too low an offset can cause troubles with the outside edge of the tire rubbing on the fender or wheel well. Rims with too high an offset can cause troubles with the inside edge of the tire rubbing on the suspension or wheel well.
Wheels with too high an offset can be fixed with spacers. Wheels with too low an offset are SOL -- you have to roll the fenders to keep them from rubbing. In the example you cited, that only about a third of an inch. I think you'll be okay.
2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
Old 12-07-2019, 06:39 AM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
Going to a wheel with a smaller offset pushes it out towards the fender, 8mm is less than 3/8" so probably not an issue unless also wider or the car is lowered.
In the opposite direction, going to a wheel with a larger offset pulls the wheel into the car. If necessary this can be compensated for by using spacers (and longers wheel bolts generally if the spacers are more than 5mm).
There is 1 more important question, what is the center bore of those steelies?
As for handling, if the tires are the identical size you will notice the weight more than the 8mm offset difference.
Edit: ok so Jay posted while I was still typing so...+1!
Posted through Tapatalk downloaded to my neural implant
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG
1999 740iA - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 330xiA - fXtXeX/son project - now April's car
2008 335xiA - winterbeater Impala replacement
2002 530i/5 - 2.5 years searching...and it is John's car
1989 535i/5 - the spare car
2002 325xiA - to be Charlotte's when she gets her license (?2019?)
Old 12-07-2019, 06:53 AM
Thanks for the responses. Not sure on the CB. It's on Craigslist and the guy is going to check for me today. After more research, I'm not sure the bolt spacing is correct.
Mine are 5x120 and I think the WRX is 5x114.5.
I'm guessing that will be a deal breaker.
The deal is killer. 4 General Altima's Arctic with 1,000 miles on steels for $400. It's a deal out of this world.
I could always get the set and mount them on my stock wheel, but a dedicated set is what I have always wanted.
Old 12-07-2019, 08:16 AM
Jay Arras's Avatar
Casual Fanatic
If you're surfing Craigslist, that's the best place to find used OEM wheels. I'd go that route. Your car will surely look a whole lot better during the winter months.
Old 12-07-2019, 09:21 AM
WRXs are great. You could pick one up to go with the wheels.
