Weird cold shift point --> normal? - Bimmerfest - BMW Forums
Old 01-08-2020, 01:52 PM
robinasu robinasu is offline
Mein Auto: 2012 X5d
Hey all, since I bought the car some months ago, when cold, the 2nd to 3rd shift point is kind of high- about 2.5k. When warm, it shifts "normally," depending on load.
It seems harmless, but has always been odd to me.
Does this happen with your vehicles? I'm driving a 2012 X5d.
Old 01-08-2020, 02:06 PM
Chill_X5 Chill_X5 is offline
Mein Auto: 2012 X5d
I have 2012 X5d and I do have the same thing happening. I"ve been told it's normal for diesels to do so. Car wants to warm up as quick as possible.
Old 01-08-2020, 02:31 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Yes. Certainly the 35d delays first and maybe second shift to warm the ZF and engine. I'll see if I can find the citation ... nope, didn't find it.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 01-08-2020, 02:55 PM
Mein Auto: 2012 X5d
Cool
Thanks - makes sense they want it hot, but then they use a **** thermostat with ****ty or no ecu logic to detect a thermostat failure.
Old 01-14-2020, 08:59 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Yes it revs high when cold but you can get xhp and flash a tune that doesn't do that
FYI: I can't see your signature because I turned off that option since people like to put big images in theirs, which this site doesn't let you block...
Old 01-15-2020, 06:55 AM
edycol edycol is offline
Mein Auto: 328i xDrive 6MT
Does that to lower NOx emissions. Diesels are not as quick to warm up as gasoline engines.
Old 01-15-2020, 09:39 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Its an engine warm up cycle:
Another way to get out of this cycle...if you have the M/S Steptronic set-up...if you push the gear selector over into the S (sport) gate...this will stop the "adaptive" funcitons of the transmission thus stopping the engine warm up cycle's programming. Once you've reached any of the requirements for ending the warm-up cycle (the speed limit is usually the 1st or easiest to acheive)...you can then push the gear select lever back into D to resume regular shift patterns.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 01-15-2020, 01:02 PM
2010xdrive35d's Avatar
2010xdrive35d 2010xdrive35d is offline
Mein Auto: 2010 X5 xdrive35d White
Happens to me too! Letting the d run a little longer in the mornings before take off makes it shift sooner. Still thinking when I do my trans service that might smooth out. Won't know until then.
Old 01-16-2020, 05:42 AM
What's funny about that "official documentation" is that it still will shift high... I got rid of the stupid behavior by using xhp.
Also higher rpm when cold does not help a diesel warm up... More cold air means a colder burn.
Old 01-16-2020, 05:53 AM
Nyc Dito's Avatar
Nyc Dito Nyc Dito is offline
Kinda officially welcomed
Mein Auto: E70 LCI 35d
Q,It didnt work for me. Sport mode acted the same when cold yesterday and today (except obviously sporty once warmed up). All good though, im doing XHP/Rod Sutphin soon.
E70 LCI 35d
E90 LCI 328i xDrive
E39 528i/5 Sport
E28 535is
E84 X1 35ix M package
E38 740i Sport
E39 M5 LMB/Blk
Old 01-17-2020, 03:23 PM
Mein Auto: 2012 X5d
I was interested until saw I need to buy another app and android phone to load it. Maybe I will get interested later. Please let me know is this is incorrect.
