How do I know which engine I have? - Bimmerfest - BMW Forums
Old 01-18-2020, 06:34 PM
Carmis Carmis is offline
Mein Auto: 2008 328xi
I know its elementary to most of you. I tried searching but the query must have been too common. How can I tell if my 2008 328xi has the N52 or any other number?
Old 01-18-2020, 06:44 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
https://www.mdecoder.com
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 01-19-2020, 08:18 AM
Thank you! I forgot all about that. Used it when I was shopping for mine.
Old 01-19-2020, 04:53 PM
ppointer ppointer is online now
Mein Auto: '11 335i, '00 323it
Usually what I do is a VIN search at http://bimmer.work. That said, your car should have the N52.
Old 01-20-2020, 11:32 AM
smassey321 smassey321 is offline
Mein Auto: 09 X5d - 06 325i
Many 328's came with the N52 but a lot have the N51. A quick look for the air pump (circled in red) will tell you it is a N51.
Old 01-20-2020, 01:13 PM
Thanks. I'll have to double check. I was just checking out something I saw in the local bMW dealership preowned lot. It's a 2011 with an N 51. I will investigate online, but if someone could tell me the key difference (s) between the two?
Thanks. !!!
Old 01-20-2020, 01:38 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Breaking in the Pony
Mein Auto: 19 Mustang GT / 05 Tacoma
Thanks. !!!
Well, the N51 is SULEV rated for states with the CA emissions standard. You're in NY and if the car in question with the N51 was originally registered in NY (or one of the other SULEV states such as NJ, MA, etc.), you get the extended emissions warranty on many of the SULEV emissions parts (including things as surprising as the fuel tank). It's a ridiculous number (15 yrs / 150k miles) on some of the components.
I know there are some intake differences, and the compression ratio is somewhat lower in the N51. In the E46 series, there was a noticeable performance difference between the SULEV and standard engines. From what I remember reading online, this difference was eliminated in the E90 series, at least at the "butt dyno" level.
If you're into DIY, a number of the N51 engine parts are different, so you need to be careful when ordering online.
Prior 44 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92 / 2015 BMW M235xi xDrive F22
Old 01-20-2020, 01:40 PM
Got it! Found another forum Thanks . I guess the SULEV(51) was produced for the States with more stringent emissions requirements. Similar build, output. Pretty insignificant unless your doing mods. I wont/cant lol. Thanks.
Old 01-20-2020, 04:47 PM
Good to know. Thanks.
