Loss of Coolant - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 01-20-2020, 09:31 AM
franan franan is offline
Mein Auto: 14 F10 5spd,3 E30 5 Speed
Loss of Coolant
I’ve been losing coolant for some time now. I checked the oil levels and everything is fine. There’s no mix of oil and coolant either. I cannot seem to find out where the problem is. I’ve checked everywhere and not one leak to be found. Very confusing. Does anyone have any suggestions?
Old 01-20-2020, 02:54 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Pressure test the system and the cap. You can rent the pressure tester at most auto parts stores.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 01-20-2020, 04:10 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
+1. Might be $100+ to “buy” a loaner and you get the refund when you return it. I have done it from Advance Auto and I had 45 days to return.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 01-21-2020, 09:58 AM
Thank you guys for taking the time to answer. Pressure test will be next.
Old 01-21-2020, 04:00 PM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
If you cant find coolant deip in the bay,. Theres in the cowl at the plastic hose inlet outlet piece that cracks or leaks at the seal. Then theres the heater core leake that dripps coolant inside the car. The carpet soaks up the coolant, bit usually stays damp or wet on the sides of the trans tunnel in the footwells.
