Got a dead battery? You wont if you had one of these! - Bimmerfest - BMW Forums
Old 03-31-2020, 01:18 PM
Antigravity Batteries Antigravity Batteries is offline
Mein Auto:
Antigravity Batteries introduces the Bluetooth Battery Tracker for Lead and Lithium-Ion Batteries.
We are proud to launch one of the first Bluetooth Battery Tracker for Lead and Lithium-Ion Batteries!
Forget about voltmeters or even popping the hood to check the battery!
The Antigravity Battery Tracker monitors your vehicle battery status through your phone or tablet by using our free Battery Tracker App (iOS or Android, Bluetooth 4.0). The app has three main pages: Voltage Test, Cranking Test and Charging Test. The simple interface makes it easy to monitor the battery's voltage, automatically check its performance during starting and test your alternator's charging operation. You can view real-time data as well as historical results (31 days) that graphically display the dates, voltages, and more.
The tracker will even send a warning to your phone if your battery is getting low and needs a charge. You can choose the alerts and notifications you want to receive.
Benefits
The Battery Tracker will allow you to monitor the level of Parasitic Draw on your vehicle’s battery and how fast the battery is discharging. For example, if in storage or during the week you find your car is draining quickly, you will be able to see this and be alerted to it graphically. If you walk within 30 ft. of your Car, the Battery Tracker will transfer the current data to your phone for you to review.
if your battery is getting low on energy and needs a Charge, you can set the Battery Tracker to Alert you by phone BEFORE you come back to a dead battery and a car that won’t start. This allows you to be alerted to put your Battery on a Charger before it’s dead. This can work great for companies with Fleets, or for persons with Cars that don’t get driven often (Sports Cars).
You can monitor your Vehicle Charge level over the span of 31 days. This allows you to see your level of discharge over the course of a month in storage, but also if you are driving the car you can see the history of when it was started, when you are driving (voltage will be higher due to Alternator Charging), and you can also see each Start the car has done over that period of time and review this on a graph that shows voltage every 2 minutes over the course of a month. Also, if anybody has driven the car while you were away, you would know because the Start will show as well as the elevated voltage when driving.
You can verify if your Vehicle’s charging system is working, and at what Voltage your Alternator is charging the battery. This could be useful to home mechanics to verify charging, and also eliminate the charging system as a potential cause of a problem.
For Racers and Track day enthusiasts, it can give data on the battery’s state of charge and alternator’s output during time on the track. Additionally, for Total Loss systems, it can document the voltage decline while in operation.
Old 03-31-2020, 03:05 PM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is online now
Mein Auto: E93 335i, somewhat mod
Being a Bluetooth device, ya gotta be within 30' of the car for it to work, yes? What about SMS messaging?
Old 03-31-2020, 03:42 PM
Mein Auto:
Yes, we could have made it work that way too, but then it will push the cost up by a significant margin. The product was designed to give you peace of mind.
Say you have two or three cars and you haven't used one of them in few weeks. You suddenly decided to take it for an early morning office meeting! Now you have doubts in your mind, what if the battery is dead or I get stuck with a dead battery later on!
With Antigravity Wireless tracker, all you need to do is pull out your phone and it will give you all the data and will send you alert as well if you need to the charge the battery!
hence you can focus on your meeting and not on "what if the car won't start"!!
